Squeak from new clutch?
Old Oct 22, 2011 | 04:44 PM
ryansalazan's Avatar
has anyone installed a new clutch and throw out bearing and once finished driven a few thousand miles and hear what seems to be the throw out bearing squeak? mine has this problem and has had it for about the 7k miles ive had the stage 4 clutch masters clutch on. however it only squeaks when the clutch petal isnt touched. once you press the clutch pedal at anytime or rpm the squeak it completely gone... anyone know how to cure this since im going to be taking off the tranny here in a few days? lol thanks in advanced!
Old Oct 22, 2011 | 05:11 PM
SSlobalt's Avatar
You mean like a constant squeak with the clutch pedal out? Can you put it in neutral and get the same squeak with the clutch out?
Old Oct 22, 2011 | 06:32 PM
yes if its in neutral with the clutch pedal out itll squeak as long as the car is on. sometimes on cold starts it wont squeak but after driving or revving for a couple of seconds it starts up again. and again yes as long as the clutch pedal is out itll squeak no matter what gear however once you start moving the engine sound is louder than the squeak and drowns out the squeak.
Old Oct 22, 2011 | 08:38 PM
anyone know what may be the cause?
Old Oct 22, 2011 | 09:13 PM
SSlobalt's Avatar
Gotta be the TOB.
Old Oct 22, 2011 | 09:14 PM
thats what im thinking just what can be done to fix it? not sure what to do
Old Oct 22, 2011 | 09:17 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Definitely the tob. Only thing you can do is replace it
Old Oct 22, 2011 | 10:06 PM
dang do you know why a new one would squeak? it functioned just fine just squeaked.
Old Oct 22, 2011 | 10:35 PM
SSlobalt's Avatar
The squeak usually means the bearing is faulty and will eventually fail.
Old Oct 23, 2011 | 01:27 AM
no kidding hmm good to know that seems like i may need to ask clutchmasters for a new one then
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
