SS/TC map sensor 2nd went bad
Old May 13, 2013 | 12:01 AM
BEG4MRC's Avatar
SS/TC map sensor second one went bad car has a catch can no blow bye i cant figure this out sucks. They last for about 2000 miles then go out i tried cleaning them as well always the one on manifold.
Old May 13, 2013 | 02:41 AM
drtibalt's Avatar
mines in the shop right now for a map sensor p0238 code tho
Old May 13, 2013 | 01:35 PM
tomj77's Avatar
Am I the only one with original map sensors lol Ben good for 75k kms. Since I bought the car
Old May 14, 2013 | 09:36 AM
Terminator2's Avatar
Pull the valvecover 99% chance you have one broken lash adjuster/rocker. The harmonics from a broken lash adjuster can cause the map to blow constantly like that. If it is p0106 that is a tune issue.
Old May 17, 2013 | 03:04 AM
BEG4MRC's Avatar
i think its because i run 23lb on stock 2bar it pops them every 2000 miles or more
Old May 17, 2013 | 08:22 AM
OBZ's Avatar
OBZ
Get a new one from autozone. 2 year warranty. I'm on about my 7th one
Old May 17, 2013 | 09:15 AM
Nope I have big turbo guys running 30 psi on stock maps for years with no problems. I ran my own car at 24 psi for 2 years on stock maps no issue. I did eventually upgarde them to 3 bar but not because they had failed.
Old May 17, 2013 | 04:43 PM
BEG4MRC's Avatar
my motor makes no noise
my motor makes no noise runs fine only does this when i run my pump tune.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
