ss/tc transmission fluid
It's actually a blend in mine to get as close to the 75w-85 viscosity as I could, 1 qt MT-90, the balance (~.7 qt) MTL.
Better than the LSJ fluid that they put in when the clutch was done as no LNF fluid was in my region, but not as good as the OEM fluid IMO, I'm changing back to the stock fluid when it gets here.
well I mixed some like you are doing, and when I tore my trans down to replace a gear, I could see at the bottom of the case that the oils separated. i wouldnt be suprised if that is what you are getting as well. A little iffy IMO. I think just sticking to one brand at a time would get you better results.
You are most likely correct, don't know yet. When I drain the blend next week to put in the OEM fluid, I'll let it sit to see if it separates. Had to do something short term, the LSJ fluid sux in an LNF tranny. MT-90 is heavier than stock and MTL was way to light.
My dealer finally got mine in today took over a week
Bought 2 qts $66 Canadian
Might be a good idea to do a Trans fluid change after so many K's on a new LNF? I had some very fine metal particles in my oils which is normal break in but will have great peace of mind with new fluid in there
Iceberg
Sep 29, 2015 12:33 PM
