Sstc Cel?
Old Jan 10, 2009 | 12:00 PM
wrathofgod's Avatar
Sstc Cel?
check engine light came on last night, just went and checked the codes, and came back as misfiring cylinder anyone else have this problem and whats the worst possible thing that could happen as a result from this?
Old Jan 10, 2009 | 12:03 PM
marcusicp's Avatar
Pull your plugs and tighten the gap to around 0.035".
Old Jan 10, 2009 | 12:07 PM
wrathofgod's Avatar
that would be a good place to start if it wasnt effin snowin already
Old Jan 10, 2009 | 01:49 PM
IsItFast?'s Avatar
Do you have an aftermarket tune? Or a custom cold air intake? If no, did you scrape anything recently? Thats the code I got when I scraped in a driveway and caused the metal condensation catcher on the bottom of the intercooler to break loose and crack the endtank. Check to see if its still there and not hanging down. PICS:
And the crack itself:::
Old Jan 10, 2009 | 02:04 PM
ecotecbreed's Avatar
I got the same code, check you air filter to see if it is wet (If you have snow in your area). Mine came from a wet air filter due to snow tht was suck through the air intake, then is made the engine suck water and create misfiring on cylinder #3.
They will change the spark plug #3 when they will receive it and they put me a new air filter.
Our cars seem to be fragile with snow! Good to know!
Old Jan 10, 2009 | 02:36 PM
Zerort's Avatar
These cars SUCK!
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
