Sstc Cel?
Sstc Cel?
check engine light came on last night, just went and checked the codes, and came back as misfiring cylinder anyone else have this problem and whats the worst possible thing that could happen as a result from this?
Do you have an aftermarket tune? Or a custom cold air intake? If no, did you scrape anything recently? Thats the code I got when I scraped in a driveway and caused the metal condensation catcher on the bottom of the intercooler to break loose and crack the endtank. Check to see if its still there and not hanging down. PICS:
And the crack itself:::
I got the same code, check you air filter to see if it is wet (If you have snow in your area). Mine came from a wet air filter due to snow tht was suck through the air intake, then is made the engine suck water and create misfiring on cylinder #3.
They will change the spark plug #3 when they will receive it and they put me a new air filter.
Our cars seem to be fragile with snow! Good to know!
