Stage 1 Install Suggestions
Old Apr 29, 2010 | 01:48 PM
D-mac's Avatar
Going to be installing my Stage 1 sensors i bought from PA
Any tips or tricks for the install ?
What are you guys using for shaving down the one sensor? Anyone have a pic of how far to cut it down or do we just shave it flat?
Any tips or tricks would be great
Going to solder and Heat shrink everything
Old Apr 29, 2010 | 02:20 PM
BYT*SS*TURBO's Avatar
Not sure if the latest ones need to be checked or not, MKriebs can chime in here, but make sure they seal tight and the O-Rings are the proper size OH and plug in the connectors firmly, don't want to see you make a GM Tech FAIL! LOL! :p
Old Apr 29, 2010 | 02:31 PM
Terminator2's Avatar
X2. My O-rings were loose and I had vac leaks at both until I got the proper size o-rings at the auto parts store. My connectors plug in very securely though. Much better than the stock T-map connector.
Old Apr 29, 2010 | 02:42 PM
northvibe's Avatar
oh ya, the kit comes with the new o-rings, they dont come with just the sensor/harness purchase.
Um file down that tab till its flush with the top of the sensor. remember to torq down the sensors per instructions!
Old Apr 29, 2010 | 11:38 PM
D-mac's Avatar
Good suggestions so far
I printed off the instructions from GM Tuner Source
You guys mostly soldering and heat shrinking your connections? I figure this would be best
Also read about some people rotating the lower sensor for clearance?
Old Apr 30, 2010 | 12:02 AM
northvibe's Avatar
I used the supplied butt splices and then wrapped the **** out of them in electrical tape.
Old Apr 30, 2010 | 08:35 AM
09blacksedan's Avatar
I sOldered Mine and then heat
shrinked then wrapped in electrical tape
you have to change the o rings on the sensors with the ones supplied in the bag
Last edited by 09blacksedan; Apr 30, 2010 at 08:35 AM. Reason: Automerged Doublepost
Old Apr 30, 2010 | 11:16 AM
D-mac's Avatar
I didn't receive any o-rings in a bag. My sensor bags were open and o-rings were already installed on the sensors.
Does PA already install O-rings for you?
If i have to get O-rings what am i looking for?
Old Apr 30, 2010 | 11:24 AM
Slightly larger Orings if they dont fit. Try them first tho, do the one on the intake manifold since its easy.
Old Apr 30, 2010 | 11:26 AM
D-mac's Avatar
OK i will try the ones they supplied, emailed PA to see if they already swapped them
I will bring a mitt full of o-rings home tonight
Install happens in the morning
Old Apr 30, 2010 | 11:46 AM
Iam Broke's Avatar
PA had mine on the sensors already. Were the bags open? mine were.
Old Apr 30, 2010 | 12:02 PM
efactor's Avatar
make sure those O-rings you receive become lubricated. Very important and ask the dealer questions of how they install so it will meet your expectations and look over the work.
Old Apr 30, 2010 | 12:23 PM
northvibe's Avatar
yes the stage kit install was very explicit about lubing them. AND using locktite on the bolts to install the sensors.
Old Apr 30, 2010 | 09:26 PM
D-mac's Avatar
Yes my sensor bags were opened
I figure that PA already installed the new o-rings cause the ones on there are pretty thick
Lubricating O-rings is always a must
Torque spec must be in the instructions?
Old May 1, 2010 | 01:50 AM
northvibe's Avatar
yup torq is in the instructions....
Old May 1, 2010 | 03:02 AM
D-mac's Avatar
This is going to happen once i wake up
Hoping everything goes well
BYT ill msg you when everything is done
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
