Stock 2009 Cobalt LNF Turbo Inlet Size
Old Feb 7, 2018 | 01:39 PM
cashmgr40's Avatar
Question Stock 2009 Cobalt LNF Turbo Inlet Size
Hi Folks,
I'm new to the forum and am looking forward to learning and sharing here!
Have a 2009 Cobalt SS LNF, K&N intake, aftermarket intercooler with aluminum end tanks (I think it's cracked - little to no boost) catless downpipe, 100k. Live 45 miles south of Buffalo, NY. The frozen tundra.
Simple question that I cannot find an answer to - what is the stock turbo inlet size on a 2009 LNF? I'm going to order a $30 intercooler pressure tester and obviously want to get the proper size. I believe it is 2.5 inches - but want to be sure. I don't want to start pulling things apart until I get the pressure tester.
Thanks in advance!
Old Feb 7, 2018 | 02:30 PM
zeeky420's Avatar
Get one from zzperformance.com
Old Feb 7, 2018 | 02:33 PM
zeeky420's Avatar
If you do a pressure test you need to take hot side pipe off turbo and test all piping and intercooler to TB
Old Feb 7, 2018 | 02:41 PM
CudaJoe's Avatar
Originally Posted by cashmgr40
Hi Folks,
Thanks in advance!
i'd say its 2.5". I mean if your off, just get a "stepped" coupler.
Old Feb 7, 2018 | 02:43 PM
cw383's Avatar
It could be a BPV solenoid failure also.
Old Feb 7, 2018 | 03:03 PM
pretty sure its 2.25"
Old Feb 7, 2018 | 09:20 PM
63 Nova SS's Avatar
Yeah I think this is correct. Can't remember, one is 2.25 and the other 2.5 I believe, which would be hotside.
Old Feb 9, 2018 | 03:40 PM
It's much cheaper to make the boost leak tester yourself, we have a how to thread
Old Feb 9, 2018 | 04:45 PM
double clutch's Avatar
This
Test post turbo, not at the inlet.
Old Feb 11, 2018 | 03:20 PM
tomj77's Avatar
U cant pressure test on turbo inlet, not should u. It will spool the turbo which shouldn't spool without oil going through it. Also the pressure will go into the crank case via pcv line. Take off cp to turbo and put it on there. 2.5 inch
Neodous
Mar 27, 2012 08:42 PM
hiltu
Jul 1, 2010 05:17 PM
shiftingloco310
May 1, 2009 09:25 AM
sheldon729
Nov 3, 2008 05:24 PM
eclipsefloyd
Apr 27, 2005 01:41 AM
