Synapse Synchronic BOV with dejon pipes
#103
just to chime in agian I may go with clear image pipes they are steel and use a short run method and may be even less than dejon plus I may be able to get them un coated which IS FANTASTIC. so I can get my own color done at Oklahoma high performance polishing. (watch the x-men movie and look at the great job they did on wolverines claws)
I will be running the synchronic BOV re circulated. With probably the gm intake if it come with the kit or the steel dejon intake . I will modify either intake to accept a hose from the bov. I will run it in its normal state so It will function exactly like the stock bov but have a better response and hold boost better.
BTW WTF is with the block off plate there is no way to block it off it would leave a hole in the turbo and it wouldn't be able to properly create boost all you nee to do is take the vacum line off it and put a washer or too behind the spring and BAM no more stock BOV.
IF I AM WRONG PLEASE TELL ME!!!!!
ALSO getting a "custom" downpipe made. just taking the stock one and cutting off the cats and putting straight pipe in its place. I looked at the design of the stock DP and have found nothing wrong with it except two cats.
https://www.cobaltss.net/forums/show...ght=stock+fail
for stock downpipe reference.
http://cgi.ebay.com/ebaymotors/ANGLE...Q5fAccessories
This should take care of the CEL.
#104
#107
ok so two different answers. I know that when I took the vacum source off the stock one it wouldn't open up under boost. did this as a test. Why can you not use the stock plate with washers behind it. Does it not give enough pressure even if I compress the spring more? does it leak boost through the vacum nipple because I can cap that. does the block off not use the stock diaprham and spring?
#109
#113
ok I will go look now. I just took my air intake out and went for a drive and year you can year the stock bov alot more.
Now i go back and try to find the bov but its packed back there and I can barley see anything
#114
08blackss/tc
Can you please explain why you need the block off plate? does it not just increase spring pressure or does it replace the spring and hold the diaphram in by its self?
I am confused on the physics behind needing one when I can already increase spring pressure by moving the spring closer to the diaphram.
#115
08blackss/tc
I believe you are supposed to take the spring out and yes, the block off plate holds the diaphram in and also removes the vacuum line.
#118
you dont need a block off plate for MY SETUP
maybe for sychronic setup
i use a bov
pm me
i will make a vid soon,,,,, i use turbo xs BOV
#120
pm me i will tell you its pointless telling you on a thread because people will still tell you that you need a block off plate so pm me so you can have it saved on what to do
i want to make a video now but my car has up to like 6 inches of snow around it lol
#124
Ok so you did not read my original question saying I would disconnect it from the vacuum source then
I will have to agree with PimpLay2 on this one because a block off plate is just a plate to increase spring pressure just like I was going to do with the washers and all I should need to do is cap off the nipple which in reality should not have any air coming from it seeing how it is on the inside of the diaphragm and does not receive air from the intake.
Read this post from dejon about it he suggests hooking the recirculating valve to a boost source in front of the throttle body to keep it closed under boost which is a good Idea but I wonder if i can keep it shut just on spring pressure alone without spending the rediculous 45$ for the hahn logo on a part of my engine no one will ever see.
http://www.solsticeforum.com/forum/f...osphere-53374/
it looks flat to me how can a flat piece hold in a diaphragm without a spring or do they leave the giant hole in the charge pipping by removing the diaphragm too.
#125
and if you don't want to pay $45 check this out http://btfstore.co.cc/product_info.php?products_id=35
