Synapse Synchronic BOV with dejon pipes
#151
if your going to run this bov you would need to move the maf right befor the throttle body.....or throw the air back in to the intake after the maf......the only thing wrong with this bov its going to sound like it surging always......and some say it fu*k's up ballbearing turbos...(wears them out)but then again it hasn't been tested......
#152
I'm confused even more. Synapse's BOV is a VTA BOV except if you purchase the anti-stall kit which will convert it to a bypass/recirc BOV. If that is wrong can someone explain what the anti-stall kit will do if u can run the BOV on its own to recirc?
#153
the anti-stall kit put the air back into the intake system......which we need cuz of the maf unless you move the maf.......maf would have to be on the cold side pipe and bov would have to be on the hot side
#156
as far as I know you can use any bov because it has been shown that you can vent to atmosphere on these cars, so tial would work, HKS, greddy, etc...
and why does it sound like its always surging??? as far as I have researched and seen it causes very little to no surge because it goes open upon vacum and stays open until you begin to loose vacum. in other words it is not releasing based on pressure but vacuum. and why move the maf. all you need to do is draw air in through the bov just past the maf and before the turbo. I am very close to having the pipes made the way I want by dejon and I will post a full how to with pics and videos.
#157
when you purchase the Synchronic BOV, it already comes as a recirc BOV
#158
so the Anti-stall kit makes the bov no vent air all time ......
http://www.youtube.com/watch?v=VWRXSKYrr8A
#159
#165
thanks I figured everyone on here would be able to compare it to theirs
I already have a complaint on the bov. The O-ring they use got shaved by the bov when I installed it.
I think it may be a standard O-ring I may buy another before I install.
Jn2 I know you have your reasons for wanting a dsm t-25 turbo but have you seen the big t-28, it has an upgraded compressor wheel and supposed to have the same spool as the t-25.
#167
Wish you were closer I would let you check it out and even let ya drive her around a bit
It's very sweet.
It's very sweet.
#168
#169
sounds good jn2 I hear the t-28 is a 360hp turbo I almost got one on my 2g dsm but went with the big evo 3 16g instead because it was cheaper. I wish I had gone with the t-28 though.
#171
you made the right choice in my opinion on the t-25, just when you want more power and you will the t-28 will be great because its spool is the same but has a much higher top end. The t-25 i think is a 260hp turbo I think I may be wrong. Do you have your system working and tunned already?
#174
Newest update.
I got the rest of the hot side.
I will be installing it tomorow after work and will post pics and try to upload a vid to you tube.
I had them weld a boost nipple to the elbow so I could get a pre bypass valve boost source.
