Synapse Synchronic BOV with dejon pipes
Ill be able to play with it tomorow after work. If not then on Tuesday for sure since I'm working late today. But ill just put the line back on the stock bypass and ill t off the manifold and are what happens. But the bov is tightened all the way supposedly and the ******* screw broke off after a ride which I'm pissed about. But ill see what happens
sounds odd. please try to hook it up to a boost only signal to keep it closed all the time andpost your results please. boost only is the line coming from the bottom intercooler pipe to the manifold.
just thought I would point this out dejonpowerhouse is now offering on their web page the set-up I was trying to do so I don't think I am the only one to think this way
Last edited by redcomet303; Feb 2, 2009 at 08:27 PM. Reason: Automerged Doublepost
I ran it like dave from Dejon told me to and I emailed him with pictures and he told me that I ran the lines good and just to check I did run it straight from the manifold and threw a check engine light 10 min later. So when it gets a bit waremer ill be checking for that boost leak
good luck when you fix the problem please let us know.
BTW Im excited I just got done desiging something that will be a great addition to any bov
I can't say too much but It is possible I will have to become a vendor soon.
So far no issues I have put about 30 miles on it and no cel.
The bov is working pretty good I need to do more listening but I can not hear it leaking and it deffinitly opens at any pressure I'm currently at.
I only have ports a and b hooked up right now.
I have the stock bov sealed by giving it a boost only source and I put a check valve inline
Last edited by redcomet303; Feb 7, 2009 at 07:11 PM. Reason: Automerged Doublepost
