throttle position help
I installed a Pwerks Turbo kit on my car and relocated the maf. Now when going into boost in 2nd and 3rd sometimes in 3rd it'll go to redline but sometimes at wide open it'll pop a p0101 code and go lean and throttle position goes to 66% sometimes down to 41%. what could be causing this? tuning with hpt.
I saw the pic you had up the other day. Remove the lines from the BPV solenoid and plug the one on the lower CP. You can remove that solenoid but you have to leave the wastegate solenoid on the car and just plugged in.
