throttle position help
Old Jun 5, 2011 | 02:21 PM
paintballerr78's Avatar
I installed a Pwerks Turbo kit on my car and relocated the maf. Now when going into boost in 2nd and 3rd sometimes in 3rd it'll go to redline but sometimes at wide open it'll pop a p0101 code and go lean and throttle position goes to 66% sometimes down to 41%. what could be causing this? tuning with hpt.
Old Jun 5, 2011 | 02:43 PM
peachpuff's Avatar
Start by posting a log.
Old Jun 5, 2011 | 02:51 PM
cmiller8006's Avatar
Did you hook up the stock boost control solenoid? Even if you are running a mbc it HAS to be hooked up in order to work right.
Old Jun 5, 2011 | 04:26 PM
We still have a vacuum line connected to it
Old Jun 6, 2011 | 01:51 AM
could it be cause the stock vacuum block 2 of the 3 vacuum ports are blocked
Old Jun 6, 2011 | 09:50 AM
BYT*SS*TURBO's Avatar
I saw the pic you had up the other day. Remove the lines from the BPV solenoid and plug the one on the lower CP. You can remove that solenoid but you have to leave the wastegate solenoid on the car and just plugged in.
Old Jun 6, 2011 | 12:16 PM
i dont have a vacuum barb in my lower cp can i just T the line into something else?
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
cw383
Sep 30, 2015 12:41 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
