Ticking under boost!!
So i was on my way home from school and got on it a little and noticed a ticking noise that sounds like its the turbo, but the car still boosts fine up to 22psi. Car still has crazy power. Coolant is fine. Wasnt using the heater so i dont think it was the fan. Its about 60 degrees outside. Just filled up today so could it be the fuel? An exhaust or gasket leak? I really hope its not the damn turbo because i just got the motor replaced last month due to the porus block. Any help would be great. Thanks.
it's the turbo, I had the same problem with the OEM TC, out of nowhere the TC just started to tick, found out later the bearings where packed with baked oil.. since your engine got replaced under warranty, you should go back to the dealership and tell them before it to late.
It's the rivet on the internal wastegate flap. See thread here: https://www.cobaltss.net/forums/2-0l...88/index2.html
This is apparently common with internal-wastegate turbos. Nothing to worry about.
can i still run the car or should i let it set before i go to the dealer. my buddy wont be home til friday to take the tune off, is it going to be ok to drive or just dont risk it? also would my tune havve created this problem with the heat? Thanks guys this helps a lot
I like how you think lol. I would do that if i had the money to lol
Last edited by hawkssoccer11; Oct 19, 2011 at 07:57 PM. Reason: Automerged Doublepost
I noticed mine making that noise after running it at 25psi on ehtanol. I thought it was the turbo hating me lol it is!
LOL at that link SSlobalt... Everyone got pissed at each other after they answered the question haha
Sl0wbaltSS
Nov 21, 2018 11:11 PM
