Ticking under boost!!
Old Oct 18, 2011 | 08:55 PM
hawkssoccer11's Avatar
So i was on my way home from school and got on it a little and noticed a ticking noise that sounds like its the turbo, but the car still boosts fine up to 22psi. Car still has crazy power. Coolant is fine. Wasnt using the heater so i dont think it was the fan. Its about 60 degrees outside. Just filled up today so could it be the fuel? An exhaust or gasket leak? I really hope its not the damn turbo because i just got the motor replaced last month due to the porus block. Any help would be great. Thanks.
Old Oct 18, 2011 | 09:24 PM
bump need some help quick
Old Oct 18, 2011 | 10:37 PM
gone_in_10_sec's Avatar
it's the turbo, I had the same problem with the OEM TC, out of nowhere the TC just started to tick, found out later the bearings where packed with baked oil.. since your engine got replaced under warranty, you should go back to the dealership and tell them before it to late.
Old Oct 19, 2011 | 05:44 AM
should i take my tune off?
Old Oct 19, 2011 | 05:57 AM
FrossB's Avatar
Thread Killer
i had the same problem with mine...turns out i just had a stud loose on my 02 housing causing a little exhaust leak
Old Oct 19, 2011 | 01:35 PM
SSlobalt's Avatar
It's the rivet on the internal wastegate flap. See thread here: https://www.cobaltss.net/forums/2-0l...88/index2.html
This is apparently common with internal-wastegate turbos. Nothing to worry about.
Old Oct 19, 2011 | 03:04 PM
can i still run the car or should i let it set before i go to the dealer. my buddy wont be home til friday to take the tune off, is it going to be ok to drive or just dont risk it? also would my tune havve created this problem with the heat? Thanks guys this helps a lot
Old Oct 19, 2011 | 03:54 PM
SSlobalt's Avatar
If it is the rivet, you're not going to have any issues. It's just noisy. Keep driving. Chances are, when you take it in, they're just going to roll their eyes at you, anyway.
Old Oct 19, 2011 | 07:10 PM
rukkee's Avatar
With how noisy these LNF's are ....a video would really help..... just a suggestion. I would be paranoid too if the motor was just replaced lol.
Old Oct 19, 2011 | 07:23 PM
Dart_SI's Avatar
you could fix it with a bigger turbo
Old Oct 19, 2011 | 07:57 PM
There was a link posted by SSlobalt and theres a video on there and mine sounds just like that.
I like how you think lol. I would do that if i had the money to lol
Last edited by hawkssoccer11; Oct 19, 2011 at 07:57 PM. Reason: Automerged Doublepost
Old Oct 19, 2011 | 08:40 PM
RyRidesMotox's Avatar
I noticed mine making that noise after running it at 25psi on ehtanol. I thought it was the turbo hating me lol it is!
LOL at that link SSlobalt... Everyone got pissed at each other after they answered the question haha
Old Oct 20, 2011 | 09:52 PM
SSlobalt's Avatar
Yeah, that **** was hilarious.
Old Oct 20, 2011 | 09:58 PM
Chevycobaltss3's Avatar
have u put my tune on it yet and if u have wheres my log.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
