Tools for LNF
Old Jan 19, 2010 | 08:07 AM
mongorat427's Avatar
Tools for LNF
Does anyone make a tool for removing and replacing valve springs on the engine while its in the car ?
Old Jan 19, 2010 | 09:48 AM
cobaltltblue's Avatar
there are several companies that make a kit that puts an air hose bung in the sparkplug hole and pressurizes your cyclenders. however you will have to remove the cam shafts to get them out of the way and let all the valves close first. then you should be able to pull them right off.
Old Jan 19, 2010 | 10:03 AM
cmiller8006's Avatar
Yep. And most your dealers will ren them out. There are special tools for the timing chain and to hold the cam gears in time while the cams are out
Old Jan 19, 2010 | 11:18 AM
Tools
I have the air bung but Ill need the tool for the cam gears and maybe a little spring compressor. Thanks J.R.
Old Jan 19, 2010 | 11:24 AM
DebadgedBALT77's Avatar
Got the valves out with a hammer and socket on my honda head. and got them back in using screw drivers and muscle. Dont know the spring pressure diffrences though.
Old Jan 19, 2010 | 11:26 AM
Edubs's Avatar
J.R. - I'm not sure about the LNF, but w/ the LSJ cars the spring compressor tool has clearance issues on the exhaust side w/ the firewall. Just keep in mind, you may need to loosen some mounts and jack the motor up from the back side to tilt it towards the front bumper...
Old Jan 19, 2010 | 11:33 AM
Thanks for the info. I have a spare head and might try to fab up a compressor tool that works on it while its in the car. Im going to port the spare and need to take it apart anyways. Where can I get the cam tool ?
Old Jan 19, 2010 | 11:45 AM
Edubs's Avatar
Dealership would probably be the easiest. It's a J-tool, let me go see if I have the number somewhere on my comp so it's easy for you to research...
EDIT: Kent-Moore J-43655
I've also seen someone use zip-ties before in lieu of this tool.
Old Jan 19, 2010 | 05:04 PM
Great Thanks J.R.
I just checked it out. That is camshaft gear holding tool. Its $227 but there is a picture of it and I can make it. Its pretty simple the way it works.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
