Torque Management
Old Jan 26, 2012 | 10:08 PM
Killswitch's Avatar
Torque Management
So gonna be fully bolted and tuned here by the summer and was thinking about limiting torque in the first couple gears to help with traction but haven't really heard to much about it on here.
I was thinking something like 65-70% in 1st and 80-85% in 2nd. Anyone with experience what are you running and does it help any?
Old Jan 26, 2012 | 10:11 PM
Chevycobaltss3's Avatar
Thatll work but you need to get your Tq rated figures by figureing your actual output of boost and ect with dal,mal, and wgdc. So once those are figured you should be good.
Old Jan 26, 2012 | 10:56 PM
dakotaspeir's Avatar
#cobalthoes
I just don't press the pedal all the way down or start off with my tune off then kick it on in third If im feeling fancy. Would be sweet to limit it, but sometimes I love to hear the tires blow off : )
Old Jan 26, 2012 | 11:26 PM
tomj77's Avatar
why dont u just limit boost instead, much easier, does the same thing
Old Jan 26, 2012 | 11:31 PM
nhanson's Avatar
Feather that baby!
Old Jan 26, 2012 | 11:46 PM
nobody2u's Avatar
Yeah most people just limit boost. Especially in first gear.
Old Jan 26, 2012 | 11:52 PM
Killswitch's Avatar
or this too I was thinking either/or shoulda said that. Was mostly trying to see what other people were working with
Old Jan 27, 2012 | 05:06 AM
bravehart's Avatar
my boost is limited to 5psi in 1st and on the street i can run through first gear, full throttle with out losing traction
Old Jan 27, 2012 | 06:30 PM
skip_jones's Avatar
i run a high of 65% in first, and a high of 75% in second. you gonna run hptuners?
Old Jan 30, 2012 | 09:38 PM
mattdracing's Avatar
im bolted and trifecta tuned 23 psi. my first gear is still stock-ish power levels. second gear goes to 16 psi until i hit about 4500 rpm then its 23psi. i def gotta feather the throttle a little sometimes but i wouldnt change it. its perfect
Old Jan 31, 2012 | 12:21 AM
AARON-SS-TC's Avatar
i would obviously want to have torque managed in 1st gear, but would want 100% after that and just learn how to drive it. pending it doesnt burn up the clutch...lol
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
