Treadstone Front Mount Intercooler Kit, Beta
Old Feb 18, 2011 | 11:31 AM
  #101
ssblackstealth's Avatar
corn gas ftw....
not bad tho....something to consider for sure
Old Feb 18, 2011 | 02:02 PM
  #102
CudaJoe's Avatar
Good deal Treadstone. Maybe you should make a new thread about this group buy to speed things up and let everyone know. I wanna get this thing ASAP, cause im getting tuned first week in March.
Old Feb 18, 2011 | 02:07 PM
  #103
Rissa's Avatar
I am definitely considering this.
Old Feb 18, 2011 | 02:21 PM
  #104
CudaJoe's Avatar
Just looked on the treadstone website. Is there a reason your not offering the TR11 IC in this deal? Is it too big for the cobalt? I noticed its the same cost as the TR8 and TR8L.
Im not interested in the TR11 but Im sure Rissa would be if she plans to go big turbo since it is the same cost.
I think I would go TR8L.
Oh and Rissa
The website says the TR8L is good for 575hp. I doubt you will make higher than that anyways
http://www.treadstoneperformance.com...R8+Intercooler
TR11
http://www.treadstoneperformance.com...11+Intercooler
Old Feb 18, 2011 | 03:09 PM
  #105
Treadstone's Avatar
The TR11 has endtanks that are slightly higher of the bottom of the intercooler which would cause it to hang lower than the TR8
the next size up is the TR10, and then the TR12, both of these intercoolers will work, and have the same mounting location as the TR8, we just need to add reducers to adapt to 3" inlets on these intercoolers
Old Feb 18, 2011 | 03:16 PM
  #106
CudaJoe's Avatar
BAM! there you go Rissa. A decent intercooler at a decent price. Its $280 instead of $250.
TR10 Intercooler- TREADSTONE PERFORMANCE
Whats the turn around time should we hit 10 people? Meaning, how long would it take to make em and ship em?
also interested in treadstone logo on IC, lol.
Old Feb 18, 2011 | 03:30 PM
  #107
Rissa's Avatar
Thanks Cuda.
Old Feb 19, 2011 | 01:08 PM
  #108
pbass's Avatar
The new $290 TR1035 (10" high, 3.5" deep like the TR10, same 22" core length) has mounting ears cast into the end tank like the TR8. I want to try. Moar is betta!
Old Feb 21, 2011 | 12:30 PM
  #109
ctn2mb's Avatar
Old Feb 22, 2011 | 07:52 AM
  #110
Treadstone's Avatar
4 weeks, if we can put together 10 people, well do $250 shipped!
Old Feb 22, 2011 | 08:31 AM
  #111
CudaJoe's Avatar
ugh. I might be buying it earlier then, I want to get it on before the BYT Meet and dyno tune on March 5th.
Old Feb 22, 2011 | 08:52 AM
  #112
Treadstone's Avatar
TR8 616 cu. in.
TR10 808 cu. in.
TR12 962 cu. in.
All three intercoolers will work with this set up.
The TR8 main improvement over stock, is that it is 3.5" thick by 8" tall, and able to support more airflow through the core with this greater surface area. By just bolting this on with no adjustments to tuning, your boost pressure will increase thus netting in an approx gain of 15-20hp. The stocker is also nearly 30" long, and this excessive length increases pressure drop across the core. 90% of the cooling is done withing the first 8" of core length, the rest is just restriction. Thats why you see many high horsepower cars running vertical flow intercoolers that are only 6" to 9" tall.
Another benefit of the greater capacity is the intercoolers ability to store thermal energy, and our highly dense internal fin structure serves just that purpose, to scrub of hot air and bring the boosted air down to ambient temps.
Many copies and replicas of our TR8 intercooler have been made of the years, we were the first with that endtank design over 8 years ago, and many companies have copied our intercooler in china and are now being sold on ebay for less than 100 bucks. But many of these companies left out our particular design features of fin density, fin count, and fin structure. We have engineered our cores to be the most efficient in many different applications.
Old Feb 22, 2011 | 09:47 AM
  #113
CudaJoe's Avatar
question will the TR8L also work? my understanding is its the same size with a better flow design? it cost few hamiltons more?
Old Feb 22, 2011 | 10:46 AM
  #114
northvibe's Avatar
I second this.
Also was this install just bolt in and done? or did new holes need to be drilled for the brackets to mount?
Old Feb 22, 2011 | 11:41 AM
  #115
CudaJoe's Avatar
Originally Posted by northvibe
I second this.
The way I read the first post, it sounds like they will provide brackets 90 degree elbows and couplers. Im assuming they are providing brackets so that they mount to factory bracket locations.
If they arent, then this isnt as awesome of a deal as I originally thought, lol.
Old Feb 22, 2011 | 05:39 PM
  #116
pbass's Avatar
My TR8 install was "bolt in and done." I think I posted the details somewhere in this thread. Ryan also posted details (in his Treadstone Stage 3 thread).
Old Feb 22, 2011 | 05:43 PM
  #117
pbass's Avatar
It would make no sense to use the factory bracket locations, as they were chosen as a place to hang the small factory IC underneath the crash bar. The massive Treadstone goes behind the crash bar and uses other factory bolt holes that are more appropriate for mounting a large IC high.
The factory brackets suck. They are 2 steel pieces that slide into the front of the crash bar, then 2 more L shaped pieces that bolt to the first 2 pieces. They are rubber mounted, as any IC should be that hangs low enough to bounce off the road like my stocker did twice (although they don't keep the plastic from cracking), and whatever weight GM saved by making the end tanks out of plastic instead of casting them out of aluminum as they should have, it feels like they wasted twice that in these 4 bracket pieces. I'm not saying the factory brackets are totally useless. I kept them in case I don't find a better way to mount my new horns.
The Treadstone aluminum flat bar brackets are sandwiched behind the crash bar. PLEASE look through this thread for (1) the pic of the bracket attached to the IC out of the car, and (2) the overhead pic of the sandwiched bracket with the IC in the car.
Old Feb 22, 2011 | 06:12 PM
  #118
pbass's Avatar
Same price, according to the web page that shows the differences between the 2 ICs, but different core size. Actually there seem to be many more differences. It's designed to flow more but at lower boost levels. It might mount differently. I haven't seen one.
Old Feb 22, 2011 | 06:17 PM
  #119
PrincessTurbo's Avatar
Originally Posted by mexi_loco
funny how genuine saab's IC looks very similar to Treadstone's TR08 IC, minus the 90* elbows welded onto the genuine saab one. Here's a pic of genuine saab's for those of you curious:
not bashing either company's product...just making an observation.
Ones polished ones isn't.. The end tanks and core you can tell aren't even remotely the same. Not the size the fins..
That Crazy Steve core is just disgusting..
One thing I thought on the CS intercooler is that the welds were actually doubled up on , and for a Chinese IC that was amazing work. It looked like it was done autonomously.. Just too bad it doesn't flow well and the elbows suck ... Look at the welds on that Tread stone ... You guys need a new welder... sorry
Old Feb 23, 2011 | 03:13 PM
  #120
CudaJoe's Avatar
Purchased IC kit. I will be attending the BYT meet if anyones interested to see this thing in person and possibly come to their senses about this great deal, lol.
Im not sure if Im going to install it there at the meet or at home.
Im definately installing it at home and checking out how the fitment works. if its not complicated then I will be making two dyno sessions at the BYT meet. to show the difference between stock IC and this IC.
Old Feb 23, 2011 | 03:27 PM
  #121
ronn's Avatar
Would be great if you could install it there at the meet. I'm sure it would be a lot easier that way and we get to see the comparison to stock
Old Feb 23, 2011 | 03:30 PM
  #122
CudaJoe's Avatar
Yeah, but I message Nick, Im thinking that day is already booked and I only have 1 dyno session for sure, lol. I might install it there but I never installed an IC before and I dont know how complicated it is. I figure If I can do it at home and the fitment is good then I will do it at the meet.
Also it will give me practice so I know what to unbolt and in what order.
wait are you in L.A? are you going to the meet?
Old Feb 23, 2011 | 04:18 PM
  #123
dthomp2366's Avatar
Put me down for the group buy and I will order Saturday
Old Feb 23, 2011 | 04:20 PM
  #124
CudaJoe's Avatar
bam thats 5 people on the group buy....well minus me I already bought it.
Old Feb 23, 2011 | 04:22 PM
  #125
CudaJoe's Avatar
dthomp, Im gonna get the IC, Im gonna install it and do a how to to install it. I will then record my IATs from stock and from this IC. I present all this in a new thread that I plan to make since there really isnt a group buy thread on this forum for this yet. Stay tuned!
IC should be here in a few days and hopefully the weather is good enough to do the install. lol.
