TreadStone TR8 IC comparison to Stock.
Old Mar 17, 2011 | 09:16 AM
  #101
vahdyx's Avatar
So does mpx work better than this one?
Old Mar 17, 2011 | 09:44 AM
  #102
CudaJoe's Avatar
No I don't think "better" is the right word. I believe they would show equivalent temp changes and both would be less likely to blow an end tank. They will work the same.
Old Mar 17, 2011 | 12:27 PM
  #103
RyRidesMotox's Avatar
Did you run the stocker on a 23 psi tune before swapping?
Old Mar 17, 2011 | 01:59 PM
  #104
CudaJoe's Avatar
Nope. The sticker was at stock boost. I was suppose to have a combo tune by now so I could switch to stock but things didn't work out that way at the byt meet. I will get a combo tune as soon as I mail nick my ecu.
I know there are some strong factors here that could prevent a good comparison but this at least shows the ic works as well as stock under higher boost loads.
Old Mar 17, 2011 | 02:39 PM
  #105
Yea, from my personal experience the stocker heats up more when you start pushing the 23-24lbs boost tunes. When I ran the TR8 I noticed alot more consistency in the temps. Course humidity and ambient temps play a large roll in that as well.
Old Mar 17, 2011 | 02:45 PM
  #106
ronn's Avatar
We really appreciate your efforts here...very nice presentation and an unbiased one to boot. I never thought this unit would make much of a difference due to its elevated location behind the crash bar. As you point out, it does seem to address the plastic end tank *problem* ...although your stock end tanks looked pretty damn good .
In my opinion, they only *blow up* under higher boost levels ( holding 23 plus) or when actually hit ( and lowered beyond Pedders). I think those with aftermarket charge piping AND elevated boost over 23 are particularly vulnerable to stock IC failure.
Great job so far!
Old Mar 17, 2011 | 02:55 PM
  #107
CudaJoe's Avatar
Hey ronn,
I agree with you as the cobalts tuned to 23psi Re most vulnerable, however some members on here have had the endtanks blow under partial boost 5-7psi when gently accelerating on the highway... not sure if something collided with the stock endtank or not but I believe that is what happened to wantedss/tc's car. Thanks for the kudos
Old Mar 24, 2011 | 02:04 PM
  #108
Treadstone's Avatar
also have to take into consideration pressure drop difference, if the factory want controlling boost, you probably would see a slight increase in boost pressure, because the factory intercooler is more restrictive.
Old Mar 24, 2011 | 02:25 PM
  #109
Dart_SI's Avatar
it seems the end tank design on the tr8 is better for flow than mpx's i/c, or zzp's or even hahns. theres no erractic angles for it to follow.
just an observation i saw.
Old Apr 29, 2011 | 02:38 PM
  #110
Treadstone's Avatar
all intercooler and pipe kits in stock!
Meadowvalien
Aug 17, 2017 06:32 PM
Oct 13, 2015 09:32 PM
vjoel2011
Oct 2, 2015 12:11 PM
dieGone
Sep 23, 2015 10:20 AM
RyGuy
Sep 21, 2015 10:03 PM
