Trifecta adjustable launch control
Old Mar 17, 2011 | 02:27 PM
Boogie_69's Avatar
Just curious to see who has tried this yet and what rpm did u set it at? And if adjusted what increment did u adjust from
Old Mar 17, 2011 | 02:32 PM
Garret's Avatar
https://www.cobaltss.net/forums/2-0l...ifecta-243193/
Old Mar 17, 2011 | 02:35 PM
bogalusahondakiller's Avatar
im still trying to see what i can do. im up to 4,000 and i bog and it just rolls out in first like at a stop light
Old Mar 17, 2011 | 06:34 PM
jarhead's Avatar
That's not right something must be wrong with you're car should be really smoking them off at 4,000 rpm launch on street tires. You are the guy also having trouble with 1/4 mile and said car was bogging normal launch at the track as well?
Old Mar 17, 2011 | 07:32 PM
MS3 2 SSTC's Avatar
you should try it on 65%. it worked for me with oem rubbers...
Old Mar 17, 2011 | 08:51 PM
jarhead's Avatar
Thats where my car is set at also 65%- I just cant imagine 4,000 rpm being like a normal take off from a light. Unless he has it set at a lower percentage and is looking at the tac reading higher which is off to the high side with the LC until the car starts moving. bogalusahondakiller What percentage is you're LC set at? My car is 4800 set at 65% which is 3120 I may be able to go 70% even but some cars said they were as high as 5100 even at that he would have to be set at 80% to have a 4080 LC rpm should be spinning like crazy or at the least squaking some???
Old Mar 17, 2011 | 09:32 PM
tomj77's Avatar
do u guys preload ur axles when u launch? makes for much better launch and a good way not to break em.
Old Mar 17, 2011 | 10:06 PM
yea that was me. idk what is up with my car its running fine now. im still tinkering with it. Waiting on vince to get back with me. i was using it at 3250 at the track and it bogged on me. on the street on street tires 2500 bogged but picked right up
Old Mar 17, 2011 | 10:09 PM
My car is 5,000 so at first i went to 2500 which was 50 and now im up to 70% havent tried it since i got the car going back right again last night. the guy i ran wouldnt go from a dig
Old Mar 17, 2011 | 10:11 PM
MTE's Avatar
MTE
Mines doing fine at 3200. Going tot he track next Wed.
Old Mar 17, 2011 | 10:16 PM
we had a freshly paved track and it had vht the entire lenght. i couldnt spin at all. probably why i thought the car was acting funny. i probably needed to go to 5,000. my power steering was catching hell lol
Old Mar 18, 2011 | 02:48 AM
PrincessTurbo's Avatar
Nope. I just drop the clutch and toast em right off.. LOL can you say wheel hop and spin city
I wonder if people do that more often than letting a little friction grab them first ..
I am finding out the sweet spot after 30k and now I am about to get a new clutch .. Was starting to like this one too..
Old Mar 18, 2011 | 03:20 AM
Garret's Avatar
someone post a ******* quick street launch. it doesn;t exit with these cars.
Old Mar 18, 2011 | 03:30 AM
it better be some stickkkky ass black top
Old Mar 18, 2011 | 03:32 AM
Garret's Avatar
no kidding. I think I've launched this car about 100 times with maybe 1 of them being a winning launch
Old Mar 18, 2011 | 10:09 AM
my clutch hates me for it but riding it out like a bike it will do a pretty mean launch on the street. Only did that once and i was impressed just havent done it again
Old Apr 2, 2011 | 11:48 PM
Boogie_69's Avatar
im having trouble setting mine up for 65%. I reloaded my tune but forgot to change the settings while tuning the car. Could anyone help me out and walk me through changing the launch control
Old Apr 3, 2011 | 12:18 AM
jarhead's Avatar
Go to this page click the link below 3 posts down is a pic better than trying to explain it- Put in you're setting at a certain % in the drop down menu do not close the ezflash window or it will revert to 100% when you reopen it if you do. Then program vehicle as you normally would repeat until you get it where you want it. The rpms on the tac in LC will be the same as it was before but the rpms will be less you can tell. After you start moving the tac goes back to normal rpms.
https://www.cobaltss.net/forums/2-0l...93/index7.html
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Coballin13
Sep 25, 2015 08:43 AM
