Trifecta adjustable launch control
That's not right something must be wrong with you're car should be really smoking them off at 4,000 rpm launch on street tires. You are the guy also having trouble with 1/4 mile and said car was bogging normal launch at the track as well?
Thats where my car is set at also 65%- I just cant imagine 4,000 rpm being like a normal take off from a light. Unless he has it set at a lower percentage and is looking at the tac reading higher which is off to the high side with the LC until the car starts moving. bogalusahondakiller What percentage is you're LC set at? My car is 4800 set at 65% which is 3120 I may be able to go 70% even but some cars said they were as high as 5100 even at that he would have to be set at 80% to have a 4080 LC rpm should be spinning like crazy or at the least squaking some???
yea that was me. idk what is up with my car its running fine now. im still tinkering with it. Waiting on vince to get back with me. i was using it at 3250 at the track and it bogged on me. on the street on street tires 2500 bogged but picked right up
we had a freshly paved track and it had vht the entire lenght. i couldnt spin at all. probably why i thought the car was acting funny. i probably needed to go to 5,000. my power steering was catching hell lol
I wonder if people do that more often than letting a little friction grab them first ..
I am finding out the sweet spot after 30k and now I am about to get a new clutch .. Was starting to like this one too..
im having trouble setting mine up for 65%. I reloaded my tune but forgot to change the settings while tuning the car. Could anyone help me out and walk me through changing the launch control
Go to this page click the link below 3 posts down is a pic better than trying to explain it- Put in you're setting at a certain % in the drop down menu do not close the ezflash window or it will revert to 100% when you reopen it if you do. Then program vehicle as you normally would repeat until you get it where you want it. The rpms on the tac in LC will be the same as it was before but the rpms will be less you can tell. After you start moving the tac goes back to normal rpms.
https://www.cobaltss.net/forums/2-0l...93/index7.html
