trifecta tune Help
Old May 24, 2012 | 11:25 PM
BlackARCA06's Avatar
Question trifecta tune Help
So im typing in my mods on the checkout page etc, and im on the dual tune option and im confused. With esc on it says mild tune and with competition mode on it says power. When on the "mild" tune does that mean stock tune? Will the car still run right without going into limp mode with my aftermarket intake? Or is it just a less aggressive tune thats still tuned with my parts?
Thanks!
Also Im confused on what cable I need, whats the difference between the black box cable and Red cable.
Old May 25, 2012 | 12:44 AM
BNRacing's Avatar
get your tune from me- Bad News Racing
I'll make sure everything is real smooth and easy. Order the tune for your vehicle and the Trifecta Red Cable. I'll be emailing you for vehicle info. I'm also the cheapest way to get it. Everywhere else is quite a bit more $$$
Edit: I'll make it real easy, you need this- http://badnewsracing.net/webstore/pr...roducts_id/162
and this- http://badnewsracing.net/webstore/pr...roducts_id/201
Old May 25, 2012 | 07:19 AM
Ok thanks! I was planning to buy from you anyway...quite a few recommended ya. Will you be able to remove torque management since Im Auto?
Old May 26, 2012 | 07:22 AM
Sloco Productions's Avatar
i have a question...i bought my car from a guy who already got the tune from trifecta...do i just buy the cable and i can get whatever tunes? is it attached to my vin on my car or what?...i was lookin to upgrade boost (im on the 22psi/15psi tune) looking to go up a bit in boost (26psi ish).
Old May 26, 2012 | 10:36 AM
mongorat427's Avatar
The red cable deal is by far the best deal. You can get the updates yourself and its easy to learn. I sold a few of these setups. Go through a independent dealer and save some money .
Old May 26, 2012 | 02:09 PM
tomj77's Avatar
dont go past 23/24 psi on stock turbo, ull blow ur ringlands, it produces to much heat, stock turbo runs out of efficiency after about 24 psi and just produces alot of heat, trust me of this, alot of people have had it happen
Old May 27, 2012 | 04:44 PM
mightymouse1975's Avatar
to build on this,upgrade your clutch first. you can have him bring it in slower,but doesn't that defeat the purpose of the tune??lol
OP-wheni ha my hhr ss,i had the dual tune. when you are not in comp mode,you are on the stock tune at 15psi. when you tap the tc button twice and the dic says comp mode,you are on your tune.
Old May 27, 2012 | 05:04 PM
neumannl001's Avatar
Awesome tutorial! Thanks to everyone.
Old May 27, 2012 | 06:19 PM
Dang that blows, guess ill go with the tune being on all the time than. I dont wanna be running lean and going into limp mode all the time with all my parts. lol
Old May 27, 2012 | 08:45 PM
He can set the stock tune to GM stage 1 specs without the need for special maps also.
Old May 27, 2012 | 10:31 PM
So he can modify my "Mild" tune when comp is off so the car still runs right with aftermarket parts?
Old May 28, 2012 | 02:35 AM
i have a ky stage 3 clutch...so im not too worried about blowing it lol...
i have pretty much every supposrting mod i just need the boost kicked up a notch...or 2
Old May 28, 2012 | 11:40 AM
BNRacing's Avatar
Yes the adjustments to fuel trims, etc. are for your low boost and high boost tunes, so you would be adjusted for your mods no matter which tune you were on.
In reference to your earlier post, yes we can remove most of the torque management. You don't want to remove all of it because it would hurt the trans.
Also worth mentioning, you'll be getting a TCM tune for free also. We can make the trans shift firmer and hold gears longer.
Old May 28, 2012 | 12:36 PM
Ok cool! yea the safer the better, this car is my DD. lol
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
