Turbo Swap
Turbo Swap
Has anyone tried swapping the stock turbo with any of these:
http://cobalt.dejonpowerhouse.com/
Let me know how it went. I thought it was recommended that no higher than 23psi be ran into the LNF. Do these turbos really give 430hp, 375hp, and 450hp off of the crank of the LNF? If this is the case, then wouldn't this be one of the best upgrades out there for the SS/TC?
Oh I completely agree that you should go with the ZZP turbo kit if u have $3000+ (depending on options). To me its overkill because I only want 400-425whp.It also helps that I got the dejon 5457 kit for $800
i got my dejon kit from a member on here that was desperate for money and needed to get rid of his kit. Thats how i got it for only $800. Like I said before tho. If you have over $3000 to spend go with the ZZP kit as it comes with everything you will need. My kit was only the turbo, adapters, and O2 housing.
ThoR294
Oct 4, 2015 08:44 PM
