Use Seafoam to De-Carbon intake valves
what about water/meth injection? any chance the that could clean it up a bit? Im not sure if the mixture would be hot enough at that point to steam... if it did i think it would be pretty good.
Brake Booster.
I don't give a **** if it's DI or not. That doesn't make a damn difference. The SS/TC isn't the only DI car out there. Just suck the **** through the BB and be done with it. That's how it's done. If you don't believe it, check some VW forums, or some Audi forums.
and you dont have to pour it through the brake booster line there is a lil line that comes off the top of the manifold that is real easy to do aswell
copson- are you stock or booosting over 20psi?
I wonder if anyone else has the same problem with getting oil caked on the intake valves or even the exhaust valves like that?... GM should have installed an Oil catch can in the first place..
After you use "Seafoam" or any other product to remove the oiled-caked intake valves, your next step should be, is to install an "Oil Catch Can", this will prevent it from happening again.. boosting over 5-30psi causes oil to leak/seep into - vacuum lines, intake manifold, charge pipes, intercooler, etc - pretty much anywhere forced/pressurized air will push oil and will leak/seep oil into or out of..
This has been reiterated time and time again.
Brake Booster.
Brake Booster.
the oil catch can solves this problem - its should be the first mod done on the car when someone picks it up from the stealership..
Look at the valves!!!
Thanks for posting up the pics. The correct way to use seafoam is to warm engine proper operating temp. suck 1 cup of seafoam thru intake slowly. engine will rev on its own. don't stall the engine. smoke will come out the tail right away. shut engine off when cup is empty. let engine sit for 20 mins. yes 20 mins. then go for a drive till it stops smoking. check engine light will come on and should go away in 10 - 30 miles of driving. if you don't do this, your valves will gum up and seize. if you damage a injector or 4 then you got warranty. even with a catch can, you will still have to do this once a year.
cheers
cheers
#36
cheers
cheers
