Vacuum Routing
(1) Evaporative Emission (EVAP) Canister Vent Solenoid Valve
(2) EVAP Canister
(3) Non-Return Valve
(4) EVAP Canister Purge Solenoid Valve
(5) High Pressure Fuel Pump
(6) Camshaft Position (CMP) Actuator Solenoid
(7) Charge Air Bypass Valve Solenoid
(8) Turbocharger Bypass Valve
(9) Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor
(10) Turbocharger Wastegate Actuator
(11) Turbocharger Wastegate Diaphragm Valve
(12) Camshaft Position (CMP) Sensor
(13) Ignition Coil/Module and Spark Plug
(14) Fuel Injector
(15) Charge Air Cooler (CAC)
(16) Intake Air Pressure and Temperature Sensor
(17) Throttle Body (TB)
(18) Manifold Absolute Pressure (MAP) Sensor
(19) Fuel Rail Pressure (FRP) Sensor
(20) Engine Coolant Temperature (ECT) Sensor
(21) Engine Exhaust Manifold
(22) Turbocharger
(23) Heated Oxygen Sensor (HO2S) 1 and 2
(24) Catalyst
(25) Crankshaft Position (CKP) Sensor
(26) Fuel Pump Module
(27) Accelerator Pedal
(28) Theft Deterrent
(29) Data Link Connector (DLC)
(30) Malfunction Indicator Lamp (MIL)
(31) GMLAN Serial Data
(32) Engine Control Module (ECM)
VERY LARGE BUT HOPE IT HELPS.
Wow thanks sheldon729! I know this is probably a really noob question but, does the piping from the turbo go to the intercooler right up in the bumper and then go into the throttlebody etc? That piping would be the hot side piping, but what is the cold side piping then? Is it just the piping after the (15) Charge Air Cooler (CAC) ?
RedLined
09-09-2015 09:11 PM
