Want to remove BOV
Old Dec 13, 2012 | 11:50 PM
etnies's Avatar
Originally Posted by SSlobalt
When you unplug it, you have a vacuum leak, so your car will rev higher and run like crap. That is an interesting setup. It's a BPV and BOV set up in tandem, with a "T" in the vac line. I don't know what that 1/8" line is for, though. If it runs fine, leave it. Some have run the BOV's with no issue, while others have multiple issues. To get rid of it you will have to buy a new hotside chargepipe that doesn't have a BOV flange. You might be able to trade someone that wants a BOV setup.
When I removed my bov i made a 1/4 inch think peice from aluminum that covers the whole you leave without a bov then just put on a new gasket and bam I'm back to bpv. I'll post a pic n the morning but don't have one atm
Old Dec 19, 2012 | 10:53 AM
05RallyYellowSS's Avatar
Shipped!!!
Good luck with the car...
Old Dec 20, 2012 | 12:53 AM
09BlackSSIL385's Avatar
I've run a bov in tandem with the stock bpv for almost a year now. I never had any issues with af ratio at all. However, like the guy says, it doesn't "wooosh" like most bov's will do. This is the case in lower rpm's and lower levels of boost. If i boost to anything above 10psi it will actually release excess boost into the atmosphere, otherwise it seems to only use the stock bpv to release pressure. Running the same bov as whats on this car btw
Old Dec 20, 2012 | 05:45 AM
Nfamous60's Avatar
what issues are you having with the bov? i have a bov with no tune and hav no issues with my car at he present time. get a tune for it not hard. you should be able to get a tune for the same price as new piping, no point in getting the upper if your not getting the lower, unless your not into modding.
Old Dec 20, 2012 | 06:22 AM
buildmeanempire's Avatar
No mechanical or operational issues just don't want it on there. If it provides no gains then I see no point in it being there. That and when I open the hood I see this big purple BOV staring at me... not down with purple.
Old Dec 21, 2012 | 09:38 AM
Nfamous60's Avatar
lol makes since, im thinking bout getting rid of my Tial Type Q bov.
Old Dec 21, 2012 | 02:03 PM
SSlobalt's Avatar
You're my new favorite person on this site.
Old Dec 21, 2012 | 11:58 PM
Nfamous60's Avatar
dito
Old Jan 22, 2013 | 09:22 PM
Well I finally got a chance to install the upper c/p that 05RallyYellowSS was kind enough to send my way. Been running it for a couple of days and no issues. I'm glad I put it on too cause I had to take it back to the dealer today for a new HPFP. I also gave rectorc08 the BOV for his turbo swap.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
breds2k
19
Sep 21, 2015 10:24 AM
