Weird flutter with Forge BPV
Old Jun 23, 2013 | 10:56 PM
trainplane3's Avatar
I noticed recently that I get some turbo flutter if I give it some boost (5-10psi). This never, ever happens at WOT though. The car came with the Forge BPV, so could it need re-lubed? I'm sure it isn't anything major, but I just wanna know if it just needs re-lubed or something...
Old Jun 23, 2013 | 11:00 PM
Sox-Fan's Avatar
Got Brakes?
That's the first place I'd look. Mine starts to flutter juuust a little bit when cold if it's getting close to needing service.
If that isn't it bypass your vacuum tank and see if the BOV still does it, but my money's on a good cleaning and re-lube with some quality high temp grease. Don't over grease it and don't get any on the nose of it. Either make it stick sometimes.
Old Jun 23, 2013 | 11:18 PM
Mine does it even whent its 80+ out. What grease do you use?
Old Jun 25, 2013 | 05:38 PM
Well, I can say that did the trick! Cleaned it up, and put some Mobil 1 grease on it. It's also a little louder now and seems more responsive.
Old Jun 25, 2013 | 05:41 PM
FRQ FLYR's Avatar
Mobil 1 synthetic is recommended; here's a link to proper method How to Service your Forge BPV - Mazdaspeed Forums.
You also might want to check if your valve has a green spring. They come with a green and a yellow; most have better luck with the lighter (green ) spring.
Old Jun 25, 2013 | 06:02 PM
Yep, that's exactly what I used. It also did have the green spring as well. It didn't even take much to make it move smoother. I dabbed some on my finger and rubbed around the piston, without getting any on the tip. It has a nice even coat. I cycled it by hand a few times and it seemed smoother. And like I said, it's alot more responsive now and slightly louder.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
