weird problem?
weird problem?
so i got a mpx downpipe catted and installed it i had the muffler delete it was 2 loud for my taste so i put the stock muffler back on and the car seems like it has alot more power now i have gms1 its also bosting around 19lbs instead of 22 like it did before maybe its in my head? anyone else have this happen? not that its a problem more of just a why shouldnt the no muffler have made it faster?
Are you sure you're not just thinking it is slower cause boost is lower? Might be off here but with a better flowing downpipe and no muffler means less back pressure easier to get exhaust out lower boost necessary to generate the same power as before. Just a thought.
You change the torque curve....and you will get more torque at lower RPMs....turbo or no turbo. I know this first hand as I stated above (it's a TC). That doesn't mean back pressure is always a good thing, since you give up high end torque (HP).
Sl0wbaltSS
Nov 21, 2018 11:11 PM
