weird problem?
Old Jun 23, 2011 | 09:24 PM
xcakez727's Avatar
weird problem?
so i got a mpx downpipe catted and installed it i had the muffler delete it was 2 loud for my taste so i put the stock muffler back on and the car seems like it has alot more power now i have gms1 its also bosting around 19lbs instead of 22 like it did before maybe its in my head? anyone else have this happen? not that its a problem more of just a why shouldnt the no muffler have made it faster?
Old Jun 25, 2011 | 01:31 PM
Permafried-'s Avatar
Are you sure you're not just thinking it is slower cause boost is lower? Might be off here but with a better flowing downpipe and no muffler means less back pressure easier to get exhaust out lower boost necessary to generate the same power as before. Just a thought.
Old Jun 25, 2011 | 02:41 PM
ronn's Avatar
You're getting more back pressure with MUFF in...that will increase low end torque and you CAN feel that. However, peak HP will prolly be less. I found the same thing when I added a silencer (into Muff end) to my cat back.
Old Jun 25, 2011 | 07:20 PM
tomj77's Avatar
u dont want back pressure with a turbo car, only on na or supercharged cars. That will not give u more torque
Old Jun 25, 2011 | 09:17 PM
ronn's Avatar
You change the torque curve....and you will get more torque at lower RPMs....turbo or no turbo. I know this first hand as I stated above (it's a TC). That doesn't mean back pressure is always a good thing, since you give up high end torque (HP).
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
