Whats Your Current LNF Setup
Old Jan 15, 2013 | 03:17 PM
  #176
FF_ace's Avatar
Nice... Slowly putting my car back together waiting on euthanasia to finish porting my im... Thinking about swithing my ar on my 5857 to 48 instead of the 63 I have currently
Old Jan 15, 2013 | 03:19 PM
  #177
Chevycobaltss3's Avatar
You'll have surge low end and it'll fall flat up top more...
Old Jan 15, 2013 | 04:01 PM
  #178
FF_ace's Avatar
Just trying to think of ways to decrease lag not liking full spool by 4500k
Old Jan 15, 2013 | 11:12 PM
  #179
Fastgti69's Avatar
Holy crap.
Old Jan 15, 2013 | 11:42 PM
  #180
ATLsilverSS's Avatar
I have always wondered about your turbo. And after seeing this thread the other day it really made me wonder.
http://https://www.cobaltss.net/foru...567-post8.html
Do you know where cmiller saw full boost on his? Since the setups are rather similar.
Old Jan 16, 2013 | 02:16 AM
  #181
Nfamous60's Avatar
damn full spool by 4.5k i thought it was lower then that, whats yor max boost pressure?
Old Jan 16, 2013 | 07:38 AM
  #182
cmiller8006's Avatar
I saw 20 psi by 4000 rpms but by then it was really climbing. Car would make 30 at about 4200
Old Jan 16, 2013 | 08:00 AM
  #183
FasterIsBetter's Avatar
You had a .48 a/r exhaust housing though, correct?
Old Jan 16, 2013 | 08:33 AM
  #184
Blue_Balt's Avatar
Bone Stock right now. I do have a Hahn Intake coming though. That and a few more things and then it's tune time.
Old Jan 16, 2013 | 09:51 AM
  #185
FF_ace's Avatar
Ur link dosnt work for me... Ya im running 25psi around 4400-4500
Old Jan 16, 2013 | 12:25 PM
  #186
Nfamous60's Avatar
no Cmiller ar was is a .63 am I right? 30 psi by 4200 is fine with me, DDAAAMMMNNN feb needs to hurry up and get here.
Old Jan 16, 2013 | 02:19 PM
  #187
Fface just has a reject turbo or something lol. Maybe u got a jb instead of a bb?
Old Jan 16, 2013 | 02:33 PM
  #188
.63. Cams, e85 and lots of work in the cam tables.
Old Jan 16, 2013 | 03:39 PM
  #189
NickD's Avatar
'09 SS Turbo Sedan
Hahn downpipe
Shorty Antennae
Center arm rest
Borbet LV5 17x7 winter rims
Modern Performance Powder Coated Red valve cover
On order:
Hahn Intercooler
Hahn Lower and Upper charge piping
Old Jan 17, 2013 | 05:52 AM
  #190
40rty's Avatar
Everything you see in the pic is my setup
Old Jan 17, 2013 | 08:33 AM
  #191
FF_ace's Avatar
Good stuff 40ty
Old Jan 17, 2013 | 08:36 AM
  #192
paintballerr78's Avatar
Im going to be getting zzp cams and valve springs revving slightly higher..i fully spool 23lbs by 4200 on a 5557 dbb
Old Jan 17, 2013 | 12:38 PM
  #193
Nfamous60's Avatar
i want zzp cams and valve springs myself we'll see how taxes go, 40rty no thats showing off lol.
Old Jan 17, 2013 | 01:10 PM
  #194
LE5_AJ's Avatar
**** i don't have much. CIA Short ram, catless 3" turbo back exhaust, Synapse IC, Termi tuned, Driver mod, pixie dust. Scoots pretty good but I have the typical issue of traction. You guys need to kick your asses into gear and figure out decent mods for traction instead of putting more useless hp in. Cause I don't want to have to make the **** myself.
Old Jan 17, 2013 | 03:15 PM
  #195
I full spool to 30lbs by 4500 with les aggressive cam tables and 4200 on more aggressive
Old Jan 17, 2013 | 04:01 PM
  #196
I love when people say driver mod
Old Jan 17, 2013 | 05:31 PM
  #197
Same here
Old Jan 17, 2013 | 05:42 PM
  #198
Dart_SI's Avatar
i cant imagine how bad traction is for you guys with more power with me. re-11's still useless on the street. ugh. but since tax time is soon and i have an ion redline now i might get some drag radials for the cobalt.
then again, traction breaks ****. lol
Old Jan 17, 2013 | 05:47 PM
  #199
ZZP Girdled 2.1L Block
ZZP 4340 H-Beam Rods
Wiseco 88mm Forged Pistons
Ported Stock Intake Manifold
3.6 DI Throttle Body
ZZP Neutral Balance Shafts
ZZP Ported Head
ARP Head Studs
ZZP #82 Valve Springs
ZZP S1 Cams
ZZP 5th Injector
Aeromotive Stealth 340
Magnaflow Bullet Side Exit
Bullseye S256ET ZZP Turbo Kit
ZZP Chargepiping, 50mm BOV, and FMIC
ZZP S4 Clutch
Fidanza Aluminum Flywheel
ARP Flywheel Bolts
ZZP Stage 2 4.45 Trans w/LSD
Pedders Coilovers
Moog Endlinks
OTTP Street Sway Bar
Autometer Sport Comp II Boost Gauge
Aeroforce Interceptor
TWM Short Throw w/ all goodies
And thats about all I'll list...
Old Jan 17, 2013 | 05:58 PM
  #200
LE5_AJ's Avatar
Yea it's almost the most important mod.
And if you're breaking **** from traction it's just showing you the weak links.
