Will new Knock sensors cure False knock?
Old Apr 17, 2013 | 01:30 PM
vahdyx's Avatar
I'm thinking about getting new knock sensors to help quell false knock.
It's my understanding that false knock grows with RPM and is typically at WOT. I get an instant 2.9-3.6 at 2k-3k RPMs barely pushing the throttle on my daily commute. Nothing at WOT. I even get knock when rev matching. This is at 0 load since the clutch is in.
I know I can just turn of my gauge annunciator for knock but I like it for when I do go WOT, so to keep my gauges from flashing all the time when coolant temps under 160-170 I am considering new knock sensors.
Or is it fine just picking up something else like exhaust rattle or solid mount rattles.
Opinions thoughts?
Old Apr 17, 2013 | 02:43 PM
DirtyBalt09's Avatar
Sounds like tip in knock. You don't get knock while cruising right?
If its tip in knock that can be changed via HPT.
As for your actual question. I personally am not sure it would matter unless there was an actual failure of the sensor.
Old Apr 17, 2013 | 10:23 PM
noorj's Avatar
Have you re-clocked them? The position has been found to cause/cure false knock.
Old Apr 17, 2013 | 10:26 PM
Pepsi's Avatar
Opinions thoughts?
Mine does the exact same thing sometimes. I think its normal. Also if you log with HPT you'll see that it doesn't pick up the false knock like the interceptor does.
Old Apr 17, 2013 | 10:55 PM
vahdyx's Avatar
I don't get it when I'm cruising at a specific speed no. I was hoping that wouldn't be the case. haha.
I have not the slightest idea how to do that.
Yeah I have noticed that too. It seems the Interceptors are hyper sensitive.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
