ZZP boost regulator
Old Sep 20, 2013 | 07:54 PM
paintballerr78's Avatar
ZZP boost regulator
I have a ZZP 259et with ZZP boost regulator no matter how many turns I give it won't go past 16lbs. The wastegate is 14lbs. Can anyone help me out. What's the correct way to route the lines with this regulator
Old Sep 20, 2013 | 08:32 PM
Killa SS's Avatar
Either lines are wrong or you have a boost leak man.
The way zzp ran mine is bottom port 9f wastegate runs too a tee that runs t9 the intake manifold and the other end runs to the in port of the b.c then the out port of the b.c runs to the top port on the waste gate
Old Sep 20, 2013 | 09:11 PM
I have a line ran from the charge pipe to the controller that's td going to the top and then other left side going to the bottom port
Old Sep 20, 2013 | 09:13 PM
Killa SS's Avatar
Is the airflow following the air on the bc port?
Old Sep 21, 2013 | 07:41 AM
raver0789's Avatar
How do you like the s259 so far. My s259et batmowheel is going in next week. I hear you are on the stock motor also Lol. Probably both of ours will blow up soon lmao.
Old Sep 21, 2013 | 01:55 PM
Can anyone help here with a picture
Old Sep 21, 2013 | 04:43 PM
cmiller8006's Avatar
Run a straight line from the lower charge pipe to lower gate nipple. Now cut the line and put a tee there. Run the tee'd line to the in on mbc, run the out of mbc to top of gate. What gate you using? If its a precision there is two bottom holes most likely, one gets blocked
Old Sep 21, 2013 | 07:19 PM
ATLsilverSS's Avatar
https://www.google.com/search?q=manu...1NTtFS5np8M%3A
This is how my hallman pro with tial 38 mm is set up
Last edited by ATLsilverSS; Sep 21, 2013 at 07:19 PM. Reason: Automerged Doublepost
Old Sep 21, 2013 | 11:42 PM
FasterIsBetter's Avatar
That's wrong for the zzp boost controller. The Hallman is a ball spring type. Totally different compared to the zzp regulator style. Cmiller is correct and you should listen to him. He has the zzp regulator style boost controller.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
