ZZP ECU Tune Dyno'd
Old Jan 15, 2011 | 01:24 PM
  #51
BYT*SS*TURBO's Avatar
Which will make it like a 4th gear pull to the car almost and def will trigger the COT. Explains the richer AFR and how it drops off a bit more up top then normal. Goto a dynojet and rerun it
Old Jan 15, 2011 | 03:05 PM
  #52
vahdyx's Avatar
Originally Posted by Terminator2
Yeah that is at least twice as long as that pull would take on the street.
The dyno was an AWD dyno, I don't know if that matters at all.
Old Jan 15, 2011 | 03:14 PM
  #53
rukkee's Avatar
Originally Posted by Matt M
The dyno graph doesn't look too bad at all for a mail order tune. We definitely don't set them up to run real aggressive because every car is a little different and the tune needs to be safe. As far as the boost fade and torque numbers- this is not a typical dyno test. If you look at the chart, you can see that there was already over 6psi boost at 32mph in 3rd gear. Then it took 18.8 seconds to reach 106mph! Apparently, this dyno was set to load the car WAY more than it would ever see on the street or especially on a Dynojet. Accurate loading would have resulted in the test taking closer to 12 seconds, not 18+. Because of this unrealistic load, the torque numbers are higher than they would normally be. The boost spike is also higher than normal due to the increased load, which inflates the torque numbers. The long pull is also likely responsible for a little more boost drop at high RPM as well. Exhaust pressure would be through the roof trying to run 20+ psi for several seconds with the stock turbo and stock exhaust. I'm guessing that the 16.6psi at the end of the pull was more of a result from the extreme exhaust pressures not allowing the turbo to spin fast enough to support 18-20psi as it normally would. Decreasing the load would most likely lean out the AFR a little as well.
Thanks for clearing that up Matt..... I was guessing there was something off with the dyno .... but i'm no expert . That and 24psi dropping to 16.5 seemed extreme.
Old Jan 15, 2011 | 03:20 PM
  #54
KnightSS/TC's Avatar
Interesting thread.......................
Old Jan 15, 2011 | 07:48 PM
  #55
Wangspeed's Avatar
I'm not sure why you are giving me a "what the hell" when I have to come on here and read false information that you are posting about us. I simply stated that you either looked at the file wrong, or it wasn't our file. Now that you are saying "the table" tells me that you may not have factored in all of the tables when making that statement. Either way, it doesn't matter. Your statement was false. The only place we decrease timing is at moderate loads in the main spark chart. If you look at the AFR timing and IAT timing charts, you will see that you still end up with more timing than stock in pretty much any condition. There are reasons why we set the timing charts up this way. I have done more dyno pulls on my Cobalt than everyone else that has posted in this thread combined. For these reasons, I don't care too much for coming in here and reading that we run less timing than stock and that we do stuff weird.
I just took another look at it, since it had been a few months. I recall now what I didn't like about it. I think the way the AFR spark correction was used was an interesting idea, but even under good conditions, the map I was looking at would result in less timing in many areas, IAT correction accounted for. Whatever the tune was, we went back to stock, and set it up from scratch, and my friend's been happier since.
You're right about vahdyx's dyno setup. I missed that. So if that's not how the car should behave under normal circumstances, then my apologies. He's also in Colorado, so that's going to affect things too, depending on where exactly he is.
Old Jan 15, 2011 | 08:56 PM
  #56
ronn's Avatar
Originally Posted by vahdyx
If it's hard to see, 262WHP 371WTQ
10 sec 60-100 in 3rd. Definitley something wrong. That's a huge load....like climbing a steep hill. Stock street conditions on a level road is 8.2 sec. Don't know how much that would effect the actual HP and Torque numbers though....boost for sure.
Old Jan 15, 2011 | 09:33 PM
  #57
vahdyx's Avatar
Guess I hate to digress, but what exactly is happening here? I'm reading and not following. Is my tune messed up or was it a bad dyno?
Also wangspeed, I live in Wheat Ridge, Colorado which is 5459 ft above sea level and the test was 5480 feat above sea level.
It wasn't to cold out, I'd say 40 degrees.
Old Jan 15, 2011 | 10:13 PM
  #58
ronn's Avatar
Nothing..when you post something like this your gonna get various takes on it. I see it's *corrected*, so that should have factored in elevation, but I'm not positive on that. Also higher elevation will effect boost levels as well. As far as the dyno goes...your car was definitely under a higher load than I would have expected, since your acceleration times were much LOWER than stock! How that would effect the actual HP/Torque readings is really an unknown, but it looks like the higher loads may have caused a very peaky boost curve. That prolly had an effect on the low terminal HP..should have been higher by around 20HP...climbing almost ALL the way to redline. yours is relatively flat.
As a reference, here's my dyno...not trying to steal your thunder here...just for a perspective so you can get an idea of what I'm talking about as far as HP:
Old Jan 15, 2011 | 10:41 PM
  #59
Matt M's Avatar
As Ronn pointed out, you are going to get conflicting comments. The bottom line is this- everyone agrees that the tune is safe. You also stated that you felt a huge power gain since you added our ECM and that the car is more fun to drive. At that point, the case is closed. You have a good mod.
Old Jan 15, 2011 | 10:52 PM
  #60
Matt M's Avatar
The problem is that everyone is "happier" with the changes that someone makes to their car when they are telling them that it is screwed up. This happens every day in the world of modding cars.
Old Jan 15, 2011 | 11:44 PM
  #61
vahdyx's Avatar
I do feel the gains and I'm very impressed with the performance and I ordered my downpipe and intake tube so I should be freeing up some air for next dyno. I'll be sure to find a dynojet instead of this all wheel drive one.
Old Jan 16, 2011 | 03:30 PM
  #62
coryss08's Avatar
I also dynoed at the same place. With gm stage 1, cia charge pipe, cia catted DP, and K&N intake. And my boost was spikeing 28 on there machine, i gotta look for my charts. I put down 265hp and about 362trq. I didnt care for this dyno, it did seem like there was too much load also they had to spray the rollers alot to get traction.
Old Jan 16, 2011 | 04:52 PM
  #63
Matt M's Avatar
I wonder why they set the load so high. It sounds like a good place to dyno your diesel truck.
Old Jan 16, 2011 | 06:24 PM
  #64
leoaa777's Avatar
That tune seems to be absolute trash.
My ss did 250 whp sae corrected and 25ish wtq sae with a drop in and 3 inch homemade downpipe.
I did the tank bypass mod and torque spiked to 26ish wtq sae on a dynojet.
Not tune, nothing, 4th gear pull. 16-17 psi at 98ish degrees F.
How can a tune only net you roughly 10-15 whp?? Wasted money.
Go at least trifecta or hp custom tune. I'm no longer a dealer nor trying to push it neither but I give respect where is due.
Old Jan 16, 2011 | 06:36 PM
  #65
vahdyx's Avatar
Negative! ZZP tune is great.
Old Jan 16, 2011 | 06:40 PM
  #66
ronn's Avatar
Think you need to CAREFULLY read this thread before making that statement.
Hint: Dyno placed a HIGH LOAD on the car.
Old Jan 16, 2011 | 06:42 PM
  #67
SOHC24powa's Avatar
indeed.
Old Jan 16, 2011 | 06:43 PM
  #68
sundevil07's Avatar
unbelievable
Old Jan 16, 2011 | 08:38 PM
  #69
rukkee's Avatar
This is one of the things that has driven me nut's for years about this place ....... When will people learn........... you can not compare dyno numbers from different dyno's .... from different area's ..... under different condition's . Who cares what you put down compared to someone else ......unless you were waiting in line to dyno on the same machine right after them .... thats the only way to get a decent comparison.
Dyno's are a tuning tool ...... not a benchmark!
Old Jan 16, 2011 | 09:26 PM
  #70
Matt M's Avatar
It's interesting that you mentioned the correction factor but then also mentioned the temperature. While most people will realize that the correction factor takes the temperature out of the equation, it actually goes further than that. If you are familiar with the LNF ECM, you know that it adjusts boost in attempt to maintain a target air-load. Typically known as "learn down", this feature causes the boost to decrease in cold temparature driving and increase in warm climates in order to maintain the target air load. Therefore, the power that the engine makes remains similar in a wide range of weather conditions. Now for the important part- Even though your car was making the typical 240-245whp for a stock SST, the 98 degree temps caused the dyno to correct the power output UP to 250. Dyno the same car again on a 20 degree day and your corrected HP will drop to around 230. To sum it up- dynoing your stock LNF on a hot day is the best way to put down good numbers!
Old Jan 17, 2011 | 04:39 AM
  #71
I would never knock anything ZZP does or has done...................
Old Jan 17, 2011 | 10:32 AM
  #72
This is why you should always enlist the help of a local customer tuner when available. And this is in no way meant to knock ZZP or anyone at all, its hard to offer a OTS tune that covers EVERY vehicle safely and then competes with the power of a well tuned, custom tuned car. It just is.
I would rerun a 3rd gear pull on a dynojet and Ill bet it looks better
Old Jan 17, 2011 | 11:37 AM
  #73
Matt M's Avatar
I am going to have to disagree with what you said. Sure it can work to the customer's benefit, but most of these "local" tuners don't know what they are doing. There really is only a handful of tuners who could make our LNF ECM better with a custom tune. For each one of these qualified tuners, there are 20 more self proclaimed tuning experts with an HP Tuner box and a willingness to butcher someones file in search of a "better" tune.
Old Jan 17, 2011 | 11:40 AM
  #74
I mean in terms of power numbers. Not reliability or quality of tune. Just purely from a number standpoint.
Edit: And I should change it to say a GOOD local tuner lol. I really meant no offense or knock towards you or your tune.
Old Jan 17, 2011 | 11:58 AM
  #75
Matt M's Avatar
No offense taken. I just want to point out that there are not many good local tuners out there when it comes to the LNF.
