ZZP Intercooler
ZZP Intercooler
Is there any performance difference between the standard and the increased clearance intercoolers ? Would either of the two better to run on a gms1 car then the other ? Our would one produce more lag in having to pressureize a larger core ?
Your power gains on these cars comes from things like torque-management, boost, waste gate duty cycle, desired air load, and timing. The GMS1 tune is a "canned" tune. It will not change any of these factors because there is a new intercooler on there. As far as the tune is concerned, there is only a difference in IAT2 readings. Will the intercooler gain you any power in the winter? No. Will it gain you any power in the summer? A little bit, but only in short bursts. Your main benefit of a metal intercooler, with the stock turbo, is reliability.
