ZZP Intercooler
Old Oct 18, 2012 | 06:50 PM
QuickSilver_SS's Avatar
ZZP Intercooler
Is there any performance difference between the standard and the increased clearance intercoolers ? Would either of the two better to run on a gms1 car then the other ? Our would one produce more lag in having to pressureize a larger core ?
Old Oct 18, 2012 | 09:06 PM
SSlobalt's Avatar
There's no lag with the larger unit. The only reason they made the smaller unit was to pacify the patrons looking for a little more ground clearance. If you're not "big-turbo," you can use either without noticing any difference.
Old Oct 19, 2012 | 06:53 AM
Makes sense. Would there be any hp gain with either of the intercoolers over the stock unit on just a gms1?
Old Oct 19, 2012 | 11:26 AM
Cobe's Avatar
Yes you would notice any difference with a bolt on until your learn down hit you.. lol
Old Oct 19, 2012 | 11:28 AM
2009CobaltLT's Avatar
Was this an actual sentence?
Old Oct 19, 2012 | 12:10 PM
^^^^ Lol.....
However , I am gms1. So i was under the impression that it removes the learn down feature ?
Old Oct 19, 2012 | 12:49 PM
SSlobalt's Avatar
Is there such a thing as a triple-negative?
Old Oct 19, 2012 | 12:51 PM
SSlobalt's Avatar
^^^^ Lol.....
Your power gains on these cars comes from things like torque-management, boost, waste gate duty cycle, desired air load, and timing. The GMS1 tune is a "canned" tune. It will not change any of these factors because there is a new intercooler on there. As far as the tune is concerned, there is only a difference in IAT2 readings. Will the intercooler gain you any power in the winter? No. Will it gain you any power in the summer? A little bit, but only in short bursts. Your main benefit of a metal intercooler, with the stock turbo, is reliability.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
