ZZP PCM Install
#51
I'm having the same issue; When it doesn't start, I have to "play" with the clutch pedal a bit. I don't have this issue with the stock PCM at all.
Matt, if you're still monitoring this thread, do you guys see this more often at ZZP and if so what kind of solutions do you suggest?
__________________________________________________
Black 2010 SS/TC – G85 |Debadged | GMS1 | Hahn 3” DP and Catback | AEM intake | GM racing pedals | OZ Ultraleggera rims |DEPO 4th gen projectors w/ 6K HIDs | smoked LED tails | 20% 3M tint |Pioneer Avic Z110bt head unit, Alpine PDX-5 amp, Focal speakers all around
http://www.cardomain.com/ride/3835837
#52
#53
Oh, and needmocheese: we're still waiting on your account of your first all-out drive with the tune. And???
#54
You need a Tech 2 do do a clutch relearn. It only takes a couple minutes so if you're cool with your local dealership, you could get one done for free. I don't know if it would help your situation or not, however.
#55
tune is nice, defiantly a-lot faster than it was. Turbo also spools up really fast now, and totally forgot i had a higher rev limit lol which i know now so the gears pull longer.
im happy so far!
the car starts on every start, you just have to make sure the clutch pedal is to the floor without an inch to spare.
other than figuring out how to get it to work, its 100% worth the money.
im happy so far!
#56
im happy so far!
im happy so far!
#58
It's been a month. How do you like it? Still making you smile? If I were you I'd find a local repair shop with a tech 2 and do a clutch relearn. There's one here in Colorado that'll do it for cheap, seyfer automotive, but that doesn't help you. But still I'm sure you can find a repair shop that'll do it so you don't void your warranty going to a dealership
#61
I didn't have any issues with the ZZP spare! No issues at all, the only thing I didn't like was since i had such high altitude the boost died out too quickly, but it wasn't the tunes fault. I just live too damn high.
So I got trifecta instead
#65
Wow hey Ross it's Chris Steve oliegs friend i had the ion redline a while ago. Now I have a Balt. 06. Was hoping you could help me tune it. Befor with buy a canned tune. 5135188089
#66
Bumping this thread, having a similar issue....I have slammed the clutch into the floor and tried it about 10-15 times AFTER doing the security relearn...should I just keep trying or take it somewhere to have the clutch relearn done?
#69
When i did the re-learn for my car the problem i had was the security light never came on. I had a buddy that worked at gm. So i put my stock pcm in the car and drove it over their and plugged in their fancy scan tool. I was able too watch the car do the re-learn procedure and i can say all is all three steps took exactly 10 minutes each. I would say instead of waiting for the security light too go out just set a timer for ten minutes and five seconds and repeat for all 3 steps.
