ZZP Ups the Ante
I don't see why not. I hit 612 on a cast wheel 259.
Yup, it didn't take much. I added the last of our E98 and maybe a gallong of your E100 and the C16. It makes a pretty nice fuel for high power setups. We need to add more injectors or a boost reference at this point, though. The 5th injector is only getting about 18psi if I'm running 42 lbs of boost. I will probably do both, as well as raise the voltage to the Aeromotive pump. I think with all of that in place we could make 800, but we don't know how well everything will hold up.
I can't even imagine trying to drive down the road in that car and give it some throttle... crazy.
I'm still wondering how much stronger the newer blocks are. The engineers are saying they are significantly stronger, especially the LUK, but that the third gen LHU and LAF are stronger than the LE5s by far.
Well, I'm not sure If I will be going that far. Would I be okay with just installing valvesprings if I want to rev out the engine to 7k with stock motor. Or you reccomend the cams.
got rid of the big boy turbo for a powerband turbo. won't sound as nice but it will definitely perform a hell of a lot better which is what we're after.
Yup, it didn't take much. I added the last of our E98 and maybe a gallon of your E100 and then added C16. It makes a pretty nice fuel for high power setups. We need to add more injectors or a boost reference at this point, though. The 5th injector is only getting about 18psi if I'm running 42 lbs of boost. I will probably do both, as well as raise the voltage to the Aeromotive pump. I think with all of that in place we could make 800, but we don't know how well everything will hold up.
Wouldn't running C16 pure have better gains than your experimental mix? Sounds like you're lowering the octane by mixing vs. running it pure. I would think eliminating the E would get you better results. Am I missing something here?
^ going by what Matt wrote and knowing it takes more Ethanol to run the same motor than regular petroleum. The ethanol makes more power, but the demand on the Fuel system is too much, so the C16 brings down the demand on the pump and injector cycle time
Am I wrong here?
Yea you are wrong in some regards. Ethanol has more properties to it then just the octane level. It has a slower, cooler burn and drops egts quite a bit as well. It has been documented and proven that E98 vs. c16 makes close to if not more than the c16 does. Issues with c16 are it is expensive, issues with e98 are it takes a whole bunch more of it than gasoline to make it work.
Kinda makes you wonder why none of the AMS Alpha 10 or Omega cars run it. They are strictly C16 for the kill tune.
I still stand behind my claim that you could make more power on straight c16 given that you won't hit the fuel system limitations so it in effect should allow you to go further.....
E98 is 115 octane, so the octane difference is minimal. Ethanol makes more power than gas, so we try to run as much ethanol as possible.
Yes, E makes more power than C16. It also has at least the same knock threshold based on our experience.
Okay yeah, I didn't know E98 had an octane rating that high. I understand the chemical properties of how it Burns and it's benefits. C16 acts quite similar.
If you don't believe that ethanol makes more power than c16, try running c16 with your stock turbo. People are picking up 10% by going to E85. I am guessing you would gain almost nothing with C16.
I also forgot to mention as Cmiller said- C16 is $90 for 5 gallons. E98 is $20 for 5 gallons. Chase is paying less than that.
I find that interesting. More digging shal ensue.
Just for numbers sake, don't you think you could take the fuel system further with the C16 and achieve higher numbers or does the difference in power making ability not make that feasible? Like, running E and running out of fuel system is still gonna make more power than taking C16 all the way past where fuel system runs out on E?
Wow that's confusing...
didnt think you guys ever tested the 2.4 to its full capability
I'm amazed everytime someone is confused about the fact that burning more fuel makes more power.
That said, Matt, your example should probably read:
5 gallons of c16 is $90
8 gallons of e98 is $32
lol
lol
ridiculous cost difference for those guys running sat/sun weekend after weekend. 6 rounds a day. thats why a lot of people around here just run methanol. and keep it all in the same place as where the fuel they tune from comes from. same fuel, same temp, consistency=win.
its like top fuel around here seriously. even the mechanics have their own rituals, let alone drivers. i've seen a guy run 4.74's 1/8 for 8 passes in a row. wanna run super pro down here???
