ZZP Ups the Ante
damm it
matt - you got to change your sig again
for drivetrain loss [based on SAE correction formula - tire size/car weight/gear ratio/etc]: 13% - 25%, then is my calculation correct for both? I used 15% because SAE is 14.7%, I rounded it out to make it simple..
based on UNCORRECTED SAE: 692.7HP add 15% for drivetrain loss that's 796.605HP at the crank!! is this true?
based on CORRECTED SAE: 715.2HP add 15% for drivetrain loss then it's 822.48HP at the crank using SAE correction formula?
matt - you got to change your sig againfor drivetrain loss [based on SAE correction formula - tire size/car weight/gear ratio/etc]: 13% - 25%, then is my calculation correct for both? I used 15% because SAE is 14.7%, I rounded it out to make it simple..
My own e generator .. ahhhh the fantasy ...
* sorry to thread jack , just too cool
I like home brew idea, it's way cheaper to put together..IMO..
Wall street is expecting $146 a barrel which put gas at $5.90 - $6.89 by the end of the month.. I could see $5-6 in PA or maybe $7 but it depends on how the market react to the increase per barrel as it's sold to big gas co.. soon the economy is going in the tank again..
oddly enough gas prices just dropped by me today
http://moneyland.time.com/2012/05/09...4-this-summer/
http://www.azcentral.com/arizonarepu...-forecast.html
http://www.telegraph.co.uk/finance/n...-for-2012.html
Where did this come from? Everything I have been reading has the price per barrel dropping or staying level?
Gas Prices Fall, Expected to Average Less Than $4 a Gallon This Summer | Moneyland | TIME.com
U.S. government cuts summer gasoline price forecast
Energy prices predictions for 2012 - Telegraph
Hell yea! Going to have very similar mods, Idk if I'll be that close to zzps numbers but I'd like to see what numbers I can put down on the dyno for sure for comparison. I started my build late November 2013 and I'm $6400 in so far, and have about another $5k to go so hoping to finish within these next few months. Picking up a 4.45 right now actually!
