06 SS/SC boost problem at WOT
Old Feb 3, 2012 | 05:07 PM
wwalker85's Avatar
I have had the problem with boost problems at WOT. You can't notice it in 2nd gear but 3rd and 4th gear hard pulls you can feel and see it above 5300 rpms. The boost gauge goes from 12.5 down to 9.5-10 after 5300 rpms. You can feel it easily because you stop to accelerate and forced to shift to next gear.
Has anyone experienced this issue or know what could cause this?
All done to the car is CAI. Just got in a ZZP 3" CAI to see if it fixes the issue.
Old Feb 3, 2012 | 06:20 PM
mrbelvedere's Avatar
check ur intercooler pump and check the belt and boost bypass solenoid
Old Feb 3, 2012 | 06:22 PM
wwalker85's Avatar
I will do that, the belt is still in very good condition...checked it the other day. only 65000 miles on car.
Old Feb 3, 2012 | 06:24 PM
wwalker85's Avatar
On Another note.. I know there are known issues with the intercooler pump, is this a known sign of the problem I am having?
Old Feb 3, 2012 | 07:22 PM
wwalker85's Avatar
just checked belt, no cracks really good condition, how can I check the BBS?
Old Feb 3, 2012 | 09:53 PM
wwalker85's Avatar
bump, really need help on this before I upgrade to stage 3...
Old Feb 5, 2012 | 05:12 PM
wwalker85's Avatar
yah fixed!
Ok I think I fixed the problem just put on new ZZP 3" CAI and shes running alot better.
I think the old cheap filter/intake was restricting the supercharger.
I did a 2nd gear pull and saw almost 15psi at WOT is this normal? I thought stock pulley was limited to 12.5.
Old Feb 5, 2012 | 05:23 PM
383_Stroker's Avatar
If you're seeing more than 12psi on a stock set-up, your catalytic converter is probably clogged and needs to be replaced.
Old Feb 5, 2012 | 05:37 PM
wwalker85's Avatar
Hmm you are probably right, after driving my car for a while esp in the heat I can hear a ticking sound in my cat..
I will check the cat. Thanks
Old Feb 5, 2012 | 06:00 PM
metzO7's Avatar
a ticking noise in the exhaust is normal mine does it every time I drive it and I have no driveability issues
Old Feb 5, 2012 | 09:16 PM
Dave1515's Avatar
Yea I have that ticking noise after I drive mine too. I guess she's just cooling down
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
