2.0 Turbo build This Weekend!
The oil feed line is already hooked up, there are 3 bolts on the backside of the motor underneath the exhaust manifold where you tap for that, and we have not yet tapped for the oil return but should be doing that monday evening. After we do a little bit more work monday will post some more pics of the progress. We are getting there not too much left to do. Hoping to have it finished up by the 15th testing for any leaks of any sort and road testing it a little bit. I will be keeping you posted.
do they make a kit for the 2.0 or are you making it yourself? im curious because i want a turbo bad i love my supercharger but you really cant beat a turbo.
there is a lot of things behind the scenes you don't know about, or whats going on.
we should be finishing up Saturday.....getting the oil pan drilled and tapped tomorrow....then need to finish installing a few odds and ends....install the wideband, interceptor, and the sportlines.......so hopefully Saturday it'll be out and about.
Indeed my friend, not going to have my exhaust on yet so its open DP we run, my new Vibrant 3" exhaust will be here by tuesday.
First off the bolts are not too bad to get off its just that a few are kinda hidded and just alot of them. Now trying to get the pan to separate with that gasket sealer on there was fun lol. Lots of prying and wiggling until it finally broke lose, and removed the dip stick. Its all good now getting drilled and tapped tomorrow then back up she goes.
Like Sunburst tsaid mainly small things left along with the 2 guages, and the rear sportlines.
So saturday should be the big day. Will have lots of pics and try to get some vids for yall as well.
Last night we finished most everything up... Just have to put the belt on, and then finish up some wires for my gauges. Thats pretty much it except i do need to install my rear lowering springs since the front are already on and then it will be ready to go besides my exhaust which will be here on tuesday.
