2.1L TVS Redline
Old Oct 17, 2013 | 01:59 PM
  #76
Gelladuga69's Avatar
Do you know how you put the filter in?
Should be attached to the cap first, then put in.
Old Oct 17, 2013 | 02:14 PM
  #77
574's Avatar
574
Holy **** no bueno. Not good to hear man
Old Oct 17, 2013 | 02:15 PM
  #78
Originally Posted by nhanson
Sucks man...not sure if that was the culprit just so you know. Ive had a couple filters come out like that and it didnt affect the engine.
x2 i had one like that once and i think i had just put it in wrong, either way that sucks!
i reeally wanna see this thing run and run well. such an all out s/c build; it's my dream really
props for sticking with it and here's to gettin it done!
Old Oct 17, 2013 | 02:30 PM
  #79
Tjolley's Avatar
This job could be a quick turn around.
Check all the rods and make sure the pistons and cylinders arnt hurt.
Old Oct 17, 2013 | 03:33 PM
  #80
mrbelvedere's Avatar
we know it was the culprit
Old Oct 17, 2013 | 04:03 PM
  #81
SSfamilywagon's Avatar
What's the part number on that filtet bro. I remember getting wrong filters like I said in your other thread.
Old Oct 17, 2013 | 04:27 PM
  #82
he put the filter in correctly he is no newbie
Old Oct 17, 2013 | 08:08 PM
  #83
Tennpenn83's Avatar
Maybe if the motor is nice and broken in, it might not affect it as much. I had about 1500 on the new motor.
Yes.. this is not my first time...
It was a Bosch filter, something like 3330 or similar. I remember looking it up in the book before I picked it off the shelf.
I don't believe there is any difference in oil filters between Gen 1 and 2 Ecotecs. The one for the LE5 block that I have should be the same as the LSJ.
Old Oct 17, 2013 | 08:18 PM
  #84
Tjolley's Avatar
All the ecotecs use the same filter.
I own a lsj and a car with a le5 in it.
I just order 10 at a time from CED
Change the filter every 1k miles in the cobalt and every 25% in my pontiac G6 le5 wife's car.
Old Oct 17, 2013 | 09:06 PM
  #85
every thousand miles!
Old Oct 17, 2013 | 10:51 PM
  #86
05RLS2's Avatar
That sucks man. Especially since it hasn't been back together for too long.
No kidding, way to throw money away for no reason.
Old Oct 17, 2013 | 10:55 PM
  #87
574's Avatar
574
Hes not changing the oil every thousand miles... just the filter. I see nothing wrong with that
Old Oct 17, 2013 | 11:20 PM
  #88
nhanson's Avatar
Nope...maybe a little over the top but a nice cushion for extra protection.
Old Oct 17, 2013 | 11:32 PM
  #89
That may be the part number you looked up, but was the correct filter in the box. Maybe its miss boxed. What the actual number on the filter you pulled out of your motor?
Old Oct 17, 2013 | 11:44 PM
  #90
Tjolley's Avatar
I use to change the oil every 1k.
But was convinced to just change the filter.
U would be surprised how shitty our filters r.
And plus Wen u buy 10 filters they r Like $6-7 each
And i send off for oil analysis.
But the car is broke now lol stupid TOB
Old Oct 17, 2013 | 11:53 PM
  #91
Tob seems to be a very common issue around here lately. Mine took a **** too couple months back.
Old Oct 18, 2013 | 12:12 AM
  #92
Bluelightning's Avatar
Got Bewst?
Awe NOOOOOO!!!! So sorry to see this man!
So what crushed the filter if infact it was installed correctly?
Old Oct 18, 2013 | 08:07 AM
  #93
Tjolley's Avatar
The filter dose look like it was put in the housing then the cap screwed Down.
Old Oct 18, 2013 | 09:40 AM
  #94
it was the correct filter
it was
Old Oct 18, 2013 | 10:37 AM
  #95
I know Jordan well enough to know he'd install the filter correctly, so you guys just chopping it off as bad filter or gonna look into. I know that worry me and I'd do a little more digging
Old Oct 18, 2013 | 10:54 AM
  #96
Staged07SS's Avatar
Administrator
Administrator
If that was a bosch oil filter, I can understand some of the distortion to it (minus what ever else happened).
I ran one of those once, and when I removed it the next oil change the pleats were all distorted. I stick with the genuine AC Delco filters. Never had a problem with them.
Old Oct 18, 2013 | 02:00 PM
  #97
it more then likely was the filter a lot of the pleats were folded over on them selves
the crank was within spec the rods were within spec he did not have a noise UNTILL A FEW MILES AFTER HE CHANGED THE OIL WITH THAT BOSCH FILTER
Old Oct 18, 2013 | 03:17 PM
  #98
Ahhh that's good news. Then some new bearings and slap her back together.
Old Oct 18, 2013 | 03:53 PM
  #99
no its not good news the only news to report will be once we tear it down
Old Oct 18, 2013 | 10:12 PM
  #100
05RLS2's Avatar
I know, I read. Replacing the filter every 1K miles is pure pointless
