2.2 lsj turbo build
Old Apr 11, 2013 | 06:27 PM
  #51
philzoot007's Avatar
ok guys. have a weird problem. im trying to bleed the clutch. im doing it vac style thru the res. when i get pedal pressure that feels about right. i start the car and try to put it in gear. it will not allow me to get the car in any gear when the engine is running. now heres where is gets really odd. if i rev the engine i lose all clutch pedal pressure. then im back at square one.
so. things im looking at.
1. bad tob
2. leak in the system some where. (although i hold vac at 20hg at the res)
3. Bad clutch pipe
4. air bound master/slave cylinders...
any other ideas before i drop the trans and replace the tob and clutch pipe?
p.s. the system does not leak. i have had the car over cardboard for a week there not a drop of anything.
if i have the car running and depress the clutch and try to put it in first. the car tries to creep forward. not much but it does.
Old Apr 18, 2013 | 07:05 PM
  #52
ok. some nice things got delivered this week.
powder coated fuel rail
and my rims.
car is up on new jack stands. ready for trans tear down tomorrow. the parts from ced should be delivered today. so i should be off and running tomorrow.
i got new pressure plate bolts, tob,clutch elbow/bleeder,hard line from the master to the bleeder and clutch pipe. so we should be good to replace anything and everything i see a problem with. wish me luck.....
Old Apr 19, 2013 | 12:33 PM
  #53
advise's Avatar
you gunna have everything in order for your tune tomorrow?
love your build
cant wait to finally drive my car tomorrow
Old Apr 19, 2013 | 05:58 PM
  #54
i was trying to get a head start on it today. i got the suspension and the fuse box and pcm bracket all out. then it started to rain on me. since i had the cars main fuse connections out i didnt really want them getting wet. so i wrapped in a plastic bag and shut the hood. calling it a day.
hopefully its not raining in the morning and i can jump into it early. couple bolts and the intermidiate shaft is off then the front and rear motor mounts then the steering input knuckle thingy. next drop the sub frame. then get a jack under the trans and remove the driver and passenger motor mounts. then bolts to bell housing. lower the drivers side of the engine so i can slide the trans out.
then do it all back wards lmao.... where is paul tuning u guys. he might come out to my house after he is done with you guys. if u are in bohemia u can come and stop by. pm me if u want. ill shoot u my address.
Old May 13, 2013 | 07:44 PM
  #55
got her running and driving today. now time to break in the motor....
Old May 14, 2013 | 12:41 PM
  #56
advise's Avatar
When's paul tuning this
Old Jul 14, 2013 | 07:15 PM
  #57
guess i forgot to update this thing. spun a rod bearing. rebuilt motor and installed it today. only thing left is bleed clutch and install fuse box.
Old Jul 14, 2013 | 07:50 PM
  #58
574's Avatar
574
You know what the cause was?
Old Jul 14, 2013 | 08:30 PM
  #59
yup. to much gasker maker got into oil and clogged up the #2 rod journal on the crank. took it apart and fished the **** out with a pic from the oilling hole. journal was to far gone to be fixed. so i threw it out lol and started with a new crank for rebuild. machine shop hot tanked the block and blew all the other hit out of the oil passages.
Old Jul 14, 2013 | 08:52 PM
  #60
Tjolley's Avatar
sweet man glad u got the block issues figured out
Old Jul 15, 2013 | 03:11 PM
  #61
yeah my machine shop had to do a bunch of work to fix what bates sold me....
Old Jul 15, 2013 | 04:20 PM
  #62
InfraRedline's Avatar
Glad to see you aren't letting it get you down and that you are pushing forward with this Phil!
Old Jul 15, 2013 | 04:36 PM
  #63
jonathan923's Avatar
i want to see this balt IN ACTION
Old Jul 15, 2013 | 04:38 PM
  #64
mrbelvedere's Avatar
that means the silicone had to pass through the oil filter and I don't see that happening
Old Jul 15, 2013 | 09:52 PM
  #65
with a filter that looked like this. when it was removed. tells me thast it wasnt seated in there properly and allowed the the stuff it didnt catch flow past it.
can u see it hapening now?
Old Jul 15, 2013 | 09:55 PM
  #66
glad to hear from ya infra. yeah im still playing with her.
its a ion redline
Old Jul 15, 2013 | 10:34 PM
  #67
no I still don't see it
Old Jul 16, 2013 | 05:20 AM
  #68
Then what do u see
Old Jul 16, 2013 | 08:31 AM
  #69
left overs
Old Jul 16, 2013 | 09:19 AM
  #70
Left overs for breakfast this morning?
Old Jul 16, 2013 | 09:24 AM
  #71
574's Avatar
574
Lol
Old Jul 16, 2013 | 09:54 AM
  #72
from the last time you went through it most people do not remove all the oil plugs and wash the block out and that can leave left overs in the block and then there are times you do it perfect and **** still ***** up
Old Jul 16, 2013 | 10:43 AM
  #73
Every time my block comes out it get complete hot tank and cleaning. Plugs and all removed. Cleaned and blown out. New rings and hone.
Old Aug 5, 2013 | 08:32 PM
  #74
first drive..... lol steering wheel. fix that this weekend....
Old Aug 5, 2013 | 08:43 PM
  #75
AHelm3's Avatar
Steering wheel is just a weeeee bit off haha. You get that booger out at 0:50?
