2.7 and 60's no power?
Hi every one I have a friend with a ion redline and we are having problems. The mods are 2.7 60's fmhe cai exhaust and a tune. The problem is it has no pull. It makes the correct boost the tune just got done by the best tuner in va. It is so bad my 06 ss with header dp and air box mod pulls him. I am thinking cat is clogged any other ideas? I am going to check pulgs and pull the injectors to check the tips see if they are clogged. He told me when he is a 2.9 42's it pulled better so it might be the injectors but I will have to check he is getting no miss fire codes no weird idle no bad fuel Econ. Thanks
His heat exchanger isn't working right and pulling timing. I sent you a PM about this. My contact info is in that.
We'll get him right, even if he has an ugly Saturn and wife!
