2.85 or 2.9
Old Apr 17, 2007 | 06:37 PM
scottd07's Avatar
2.85 or 2.9
I have the GM Stage 2 kit. I want more power now. I have a JBP header and Down pipe sitting in my room. just waiting 2 more weeks to get that put on along with a new cat-back. Would it be safe to run a 2.85 without a tune or should i just get a 2.9. where can i order either of these pullies from.
Thanks
Old Apr 17, 2007 | 06:47 PM
chipsgt's Avatar
I have been thinking about a 2.9 my self. One that is of course interchangable with the GM hub. I have no idea how much of a gain can be expected though.
Do you know if the boost bypass mod needs to be done to run this?
Bump to the top
Old Apr 17, 2007 | 08:35 PM
quickspec's Avatar
Bump to the top
I think you can buy the gm stage 3 pulley by it self, I think its a 2.9''.
Old Apr 17, 2007 | 08:51 PM
chevysalesman614's Avatar
Thanks
2.85 is O.K.....
I run a 2.9" with no worries
times, and dyno listed in sig. (found elsewhere)
use the search button.
(will P.M. dyno chart, and timeslip to origonal poster)
Old Apr 17, 2007 | 08:52 PM
syP's Avatar
syP
technically the stage 2 is 77.9mm which is 3.06
And the stage 3 is 76mm which is 2.99
and ppl said that anything smaller than a 2.9 will make the injectors go static... (do they mean GM stage 3 pulley at 2.99... or do they infact mean 2.90???)
With that being said, will a TRUE 2.90" pulley (not the 2.99) **** up the injectors?
a true 2.90" pulley (2.9) would be a 73.66mm
I noticed that CobaltPerformanceParts has a true 2.90" pulley... which is smaller than the "2.9" that GM has (really a 2.99") Will the injectors be okay:?
Old Apr 17, 2007 | 08:53 PM
Thanks
2.8" ZZP for you.
me too...
but if you can't hit 13's on stage 2, your most important MOD will be driving.
Old Apr 17, 2007 | 08:55 PM
chipsgt's Avatar
Originally Posted by syP
technically the stage 2 is 79mm which is 3.11
With that being said, will a TRU 2.90" pulley (not the 2.99) **** up the injectors?
I am pretty sure it is the true 2.9 that is safe, not GM's almost 3.0
don't post what you have heard as 100% truth.
Look at my #'s and tell me you can't run a 2.9" pulley.
come on, buddy... go post in the war stories section... get out of my performance section.
Old Apr 17, 2007 | 08:58 PM
telstaboy's Avatar
Hey Scottdo7, how long did it take you to get your jbp header after you ordered it from them? I am going on a month and they are telling me it will still be another 3 weeks.
Old Apr 17, 2007 | 09:03 PM
syP's Avatar
syP
I think you misread what i said... i was kinda typing it as i was thinking of it, so it might be partly my fault.
I was stating what i heard... and asking if this was true.
Besides, i heard that the injectors go static UNDER 2.9"... not AT 2.9" so that is why i was asking if it would be safe at a TRUE 2.90... ASKING not telling.
Old Apr 17, 2007 | 09:12 PM
RedlineBrian's Avatar
I was running a 2.9 with the GM Stage tune. Every thing seemed fine. I didn't have an A/F gauge or a way to monitor my IDC's but my car didn't blow up. The car ran pretty strong, a tune will benefit you because there is much to be had with the Stage tune. It's pretty crappy.
Old Apr 17, 2007 | 09:18 PM
M-Dub's Avatar
I'm runnin' a 2.85 and love it... not much high end gains, but lots of low end grunt! 18 PSI on a cool morning easily! 17.5 most of the time!
Old Apr 17, 2007 | 09:24 PM
scottd07's Avatar
where did you get your 2.85 at??? I order my header and downpipe 2 weeks before x-mas and got it in the middle of Feb. I just got done putting their intake on. it sounds great.
Old Apr 17, 2007 | 09:37 PM
portergraph's Avatar
contact Nate -
https://www.cobaltss.net/forums/members/nherbst454-11117/
he'll make any size and to fit GM stg2 hub
Old Apr 17, 2007 | 09:38 PM
M-Dub's Avatar
Originally Posted by portergraph
contact Nate -
That would be the fella there! He got it too me quick, and it was perfect for the Stg. 2 hub!
BLKblurr06's Avatar
I have the 2.85 that fits the GM hub from nherbst24 <---I think thats right, havent put it on yet though IMO the best buy for $50
Old Apr 17, 2007 | 09:39 PM
M-Dub's Avatar
That is the one I am using.... 2.85 polished!
Old Apr 17, 2007 | 09:41 PM
RBC's Avatar
RBC
I got exactly what you meant, I just don't think he did.
Old Apr 17, 2007 | 09:42 PM
syP's Avatar
syP
Its all good.. hope he sees this... dont wanna make anyone mad.
Old Apr 17, 2007 | 10:35 PM
camarokiller's Avatar
with my math I got 3.04? where did I screw up? Anyway I was gonna get a 2.85 made to fit the S2 hub.
Old Apr 17, 2007 | 10:45 PM
scottd07's Avatar
so i will be fine with a 2.85 with the GM tune? thanks for the input.
Old Apr 17, 2007 | 11:32 PM
Johnboy12358's Avatar
Personally I wouldnt go under a 2.9 without an AFR, and I would like to have an AFR for anything smaller than the stage 3 pulley (3")... But thats just me
Old Apr 18, 2007 | 12:32 AM
syP's Avatar
syP
not sure.. i just used a online mm to inches converter... and i doubled checked them with a few more online converters
Old Apr 18, 2007 | 01:49 AM
ReMz's Avatar
skipped reading after half a page. too lazy atm
Syp, u were right on, cheversalesman misread and made an ******* assumption.
just run a 2.9 pulley. end of story.
medic710
Sep 6, 2015 08:53 PM
CTCOBALTSSS
Oct 12, 2006 02:41 PM
Smokem10
Sep 22, 2006 11:13 PM
2006ArrivalBlueSS
Jun 6, 2006 04:46 PM
silverSS
May 27, 2006 12:43 PM
