2 ways to get more tension with smaller pullies
I feel like I need more tension since going with the 2.8 pulley, after searching supporting vendors I found two options,
http://www.ottperformance.com/Cobalt...duct_info.html
this is a larger than stock tensioner pulley... price, $18.00
and
http://www.zzperformance.com/cobalt_...=447&catid=142
this is the adjustable tensioner from zzp, price $109.99
keeping the prices in mind do you think the larger tensioner pulley will do just as good as the adjustable tensioner?
and
yea and it's some bullshit haha should be fixed sooon honestly i think one of the bolts back out and made it track wrong and then ummm come off.....even though a checked them 2 days before it happend.... moral of the story use loctite!!!!!!
and
and
The oversized tensioner pulley requires you to remove some material from the tensioner unit itself so it does not rub. Imo if you are fine with that its the best option becuase of price. I ran the oversized tensioner and stock belt on a 2.5" setup for 3 years with no issue.
If you don't like to modify the tensioner pulley there is always a new stage 2 belt you could use.
patooyee
Oct 1, 2015 01:07 PM
