2 ways to get more tension with smaller pullies
Old Feb 2, 2009 | 08:47 PM
bernandovelasquez's Avatar
I feel like I need more tension since going with the 2.8 pulley, after searching supporting vendors I found two options,
http://www.ottperformance.com/Cobalt...duct_info.html
this is a larger than stock tensioner pulley... price, $18.00
and
http://www.zzperformance.com/cobalt_...=447&catid=142
this is the adjustable tensioner from zzp, price $109.99
keeping the prices in mind do you think the larger tensioner pulley will do just as good as the adjustable tensioner?
Old Feb 2, 2009 | 08:51 PM
Black SS/SC 06's Avatar
are you running a stage two belt?
Old Feb 2, 2009 | 08:55 PM
ItalianJoe1's Avatar
Just run a stage 2 belt, that will be fine with the 2.8.
Old Feb 2, 2009 | 08:56 PM
yeah I am running a stage 2 belt but it squeaks!!
Old Feb 2, 2009 | 08:57 PM
What squeaks? Just the belt?
What brand pulley are you running? I ran a 2.8" for two years on a stage 2 belt with nmot problems.
Old Feb 2, 2009 | 10:13 PM
c0ld29's Avatar
make sure the belt isn't loose / off track. Try using some belt dressing and see if it stops if not. Or... make sure it isn't something else squeaking.
Old Feb 2, 2009 | 10:18 PM
ColeJJones's Avatar
Bannned
did we forget about the crank pulley? adds more tension, boost, and more surface area grip for less slip
Old Feb 2, 2009 | 10:24 PM
hmmm didn't come across that..
Old Feb 2, 2009 | 10:26 PM
boostedss26's Avatar
i have a 2.8 with the stock pulley. I did my 2.8 before the smaller belt came out and i just went to carquest and matched up a little bigger tensioner pulley
Old Feb 2, 2009 | 10:30 PM
ColeJJones's Avatar
Bannned
there is only like 3-4 vendors selling it. had about 3 group buys them in the last month from OTTP, MRZ and GMA.
Old Feb 2, 2009 | 10:34 PM
flash13brandon's Avatar
What are the cons of it tho because I remember some people did not recommend it...??
Old Feb 2, 2009 | 10:39 PM
CobaltVenomSS's Avatar
well bbitz06 did the ott stage 1 upgrade...and his pulley came off while driving and shredded the belt
ColeJJones's Avatar
Bannned
they didnt recommend it cause of the bolt. it was only supposed to be used once. but they are now selling the bolt with the pulley, it was torque to yield
Old Feb 2, 2009 | 10:43 PM
That's no good...Has that happened on more than one occasion or what?
Old Feb 2, 2009 | 10:52 PM
nah it was the first time...only problem his car has had
Old Feb 12, 2009 | 12:51 PM
bbitz06's Avatar
yea and it's some bullshit haha should be fixed sooon honestly i think one of the bolts back out and made it track wrong and then ummm come off.....even though a checked them 2 days before it happend.... moral of the story use loctite!!!!!!
Old Feb 12, 2009 | 12:55 PM
lsjwannabe's Avatar
and
The oversized tensioner pulley requires you to remove some material from the tensioner unit itself so it does not rub. Imo if you are fine with that its the best option becuase of price. I ran the oversized tensioner and stock belt on a 2.5" setup for 3 years with no issue.
If you don't like to modify the tensioner pulley there is always a new stage 2 belt you could use.
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
