235 WHP with only one mod!
Old May 17, 2006 | 12:59 PM
Bad GTP's Avatar
Talking 235 WHP with only one mod!
Congratulations to John Harbert, who put down 235.6 WHP and 206.8 WTQ in his ’04 Ion Redline last night! His car is bone stock, except for the INTENSE Stage 1 PCM tune we did for him last night. His fuel was a mix of 93 and 94 octane unleaded pump gas, and he doesn’t even have the boost bypass mod done.
As I mentioned in another thread, we just completed our first twelve hours of LSJ dyno tuning sessions, and we've learned a LOT! Rob Archer of Hoosier Performance and I worked together on all the tuning, and with our combined experience we were able to make some great things happen. We’ve also had the opportunity to dyno test some GM Stage flashes, and we’re proud to have produced even better results. I was pretty pumped when I got home at 2:04 a.m., and I don't think Rob would have gotten home until almost five o-clock this morning.
The HP Tuners software is functioning quite well, and we're working with them to make it even better. Notice how much healthier and consistent the air/fuel ratio is now. Also notice how much the area under the curve has increased. Looking at 4,500 RPM for example, you’ll see gains of ~ 10 WHP and ~ 13 WTQ. These numbers may seem small, but at that point in the powerband, this car is making 6% more horsepower and 7% more torque. And these are differences that you can really feel!
The INTENSE Stage 1 PCM will be intended for completely stock cars with no mods installed. You’ll be able to get it in three different varieties:
1. Binary File Only - If you already have or plan to order HP Tuners, INTENSE-Racing or Hoosier Performance can email you a binary file to fit your mods for $99.99. This would serve as an excellent starting point for you to begin your tuning, and can easily be loaded with the HP Tuners VCM Suite. No core charge, Security Relearn or Crankshaft Variation Learn procedures would be required in this case.
2. Mail Order PCM - If you want a mail order PCM, the cost will be $199.99 plus $200.00 core charge. You could then keep your original PCM if you like, or return it to us for a full refund of your $200.00 core charge. If you go this route, you won’t need HP Tuners, but you would be wise to purchase a scan gauge.
With a mail order PCM, you’ll need to perform the Security Relearn Procedure. This only takes a half hour, and doesn’t require any special tools. Here is a link to a similar procedure to the one required for LSJ-powered vehicles: http://www.intense-racing.com/docs/05secrelearn.pdf.
With a mail order PCM , the Crankshaft Position Variation Learn procedure (commonly referred to as CASE Learn) will also be required to prevent DTC P0315 (Crankshaft Position Variation Not Learned) from triggering your Service Engine Soon light. Anyone with a Tech II (such as a GM dealership) can perform this special function for you in a couple minutes. Some discretion is necessary when asking your dealership to NOT re-flash the PCM. If they re-flash the PCM, all your special tuning will be gone and un-retrievable. Many dealers will perform the Crankshaft Position Variation Learn procedure for free, while others may charge a modest fee.
3. Custom Dyno Tune – This is the ultimate way to get the best possible tune, especially for more modded vehicles. No core charge, Security Relearn or Crankshaft Variation Learn procedures would be required in this case. We would tune your cars hands-on at our facility in Plain City, Ohio (INTENSE) or Indianapolis, Indiana (Hoosier). Custom dyno tunes can get quite expensive, and average ~ $375.
We always use the latest calibration files available from G.M. as the starting points for our tunes. The latest information is available at this link: http://calid.gm.com
In case anyone is curious about our tuning capabilities, our tunes currently hold the highest horsepower 3800 N/A dyno record, the 3800 M90 supercharged dyno record and 3800 turbo dyno record. We’re not just good dyno queens either. Some of our 2005 tunes include:
1. World's fastest FWD Grand Prix (9.64 @ 146 MPH)
2. World's fastest FWD Bonneville (10.71 @ 125 MPH)
3. World's fastest FWD Regal (11.51 @ 114 MPH)
4. World's fastest 2004 Impala (11.99 @ 113 MPH)
Also, here is a link to testimonials from a few hundred of our current PCM customers: http://www.intense-racing.com/testimonial.html#PCM
p.s. - we'd like to give special thanks to Mike Vanderhorst, Chris Kinzer, John Harbert and Dan Testa for donating their cars and time to this project, and for driving all the hours they did. Howard and Brian Turner of Dyno Tune Motorsports are always great to work with, so props to them too!
p.p.s. – sorry to repeat the above spam, but we want to try and answer as many FAQ’s as possible
Old May 17, 2006 | 01:01 PM
DJNateGnau's Avatar
Sick!
Old May 17, 2006 | 01:02 PM
Bad06SS's Avatar
Very nice Scott, keep it up!
Old May 17, 2006 | 01:07 PM
CTCOBALTSSS's Avatar
Sweet numbers. I don't get how I dyno'd 242whp with gm stage 2 and an intake???
That tuning works wonders. Look at my AFR with no tuning.
Old May 17, 2006 | 01:18 PM
korax123's Avatar
Pretty sweet.
Old May 17, 2006 | 01:21 PM
1stbluSS's Avatar
I have a question are you guys able to change the redline now ?
Old May 17, 2006 | 01:23 PM
Bad GTP's Avatar
Yes, we moved the rev limiters to 7,000 RPM.
Old May 17, 2006 | 01:56 PM
VictoryRed06's Avatar
after the gm stage 2, is our car tuned for 93 octane?
Old May 17, 2006 | 02:06 PM
CTSSBowtie's Avatar
the car is tuned, stock, for 91 or better. running lower octane could damage the engine.
Old May 17, 2006 | 02:08 PM
Gorilla unit 33's Avatar
WTF is up with that 2nd run A/F?
wikkymaster's Avatar
make a tune for the 2.2!! we have just as much potential
Old May 17, 2006 | 02:19 PM
Floridas Finest SS's Avatar
I see big things happening.
Old May 17, 2006 | 02:26 PM
Bad GTP's Avatar
The red line is before, and the blue line is after.
Old May 17, 2006 | 02:30 PM
something is wrong with his car the A/F does that stock. 16.5 to 10. I don't think it could be that bad stock.
mine was off, as in the numbers, but didn't do that.
However it did go crazy with the boost bypass mod done.
Old May 17, 2006 | 02:32 PM
cobss187's Avatar
oh man u got me all excited, thats not a single mod thats a tune. i thoght u put down those numbers wit a cai or an exhaust or a decently sized pulley and it was a factory freak or somethin lol but no doubt those r sick numbers for that tune man keep it up
Old May 17, 2006 | 03:38 PM
1stbluSS's Avatar
has anyone experimented with a 7300 rpm redline....
Old May 17, 2006 | 03:44 PM
Dezod's Avatar
Man that is a pretty healthy TQ curve. Nice stuff!
Old May 17, 2006 | 03:54 PM
Bad06SS's Avatar
Rob has been to over 7600 rpms before, but not on a dyno. I don't think there's any benefit to going higher than 7K untill you have stronger valve springs and aftermarket cams.
Sorry for the off-topic Scott.
Old May 17, 2006 | 03:55 PM
SS_SC_Cobalt's Avatar
schweet!!!!
now road trip to ohio? lol
also if we already have the stg 2 pcm flash does this prevent us from getting the custom tune? do we lose the stg flash altogether?
Old May 17, 2006 | 03:59 PM
Saki XL's Avatar
You won't lose the PCM Stage 2 reflash per-say... You should more than likely retain all of the fixes the reflash makes, and they'll probably do nothing more than add the other fixes they found, and adjust the others to make the parameters run smoothly together.
For everyone else WITHOUT the Stage Reflashes (thank GOD I didn't get one... ) we now have an opportunity to get the tuning of GM Stage 2 (or better....!) without paying for well... You know... However, we still lose out on the warrantee.
~Saki
Old May 17, 2006 | 04:04 PM
1stbluSS's Avatar
thanks for the answer i too apologize for the thread jack.....
bigdeertz
Nov 17, 2016 09:41 AM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
footballplaya3k
Sep 28, 2015 11:14 AM
