274.8 whp & 253.6 wtq
Old Mar 26, 2006 | 01:21 PM
9JordonFlex9's Avatar
hey this is when that 150 buck SMS throttlebody will put u ahead maybe 2 hp..maybe get a lil more with the CAI...maybe 4 hp! 1tq :P
Old Mar 26, 2006 | 01:34 PM
Grifter's Avatar
Nice numbers.
Old Mar 26, 2006 | 01:35 PM
Bad06SS's Avatar
I'm anxious to see how restictive the stock intake is on a modd'ed car. Fast06SS is still using the stock tubing, stock filter and stock airbox. Nonetheless, I can't wait to see the times ran at IDDVII by the LSJ's!!
Old Mar 26, 2006 | 01:36 PM
Yes even though the throttle body doesnt add much hp...for 150 buck it isnt too bad for a lil extra air, it always helps with cold air coming in....got to face it...every lil bit of hp and tq helps
Old Mar 26, 2006 | 02:03 PM
Bad06SS's Avatar
You're right, every little bit does help.
Old Mar 26, 2006 | 03:23 PM
djt81185's Avatar
Yes I'll be there.
torque braces, control arm bushings and the same setup I dynoed with maybe have a TB on. Just installed a B&M yesterday. I'm ordering a spec stage 3 next week but I'm still debating about the flywheel. Is it really worth it? Also I dont have a wideband in that budget either.
Dan
If I can score a Tofu like 1.9xx outta the hole on stock tires It'll be in the low to mid 13s.
Old Mar 26, 2006 | 03:27 PM
Bad06SS's Avatar
Originally Posted by djt81185
torque braces, control arm bushings and the same setup I dynoed with. Just installed a B&M yesterday. I'm ordering a spec stage 3 next week but I'm still debating about the flywheel. Is it really worth it?
Dan
On the clutch, do a 2+ or 3+, don't do a 3. A 2+ gives you the same hold as a stage 3 but with a stage 2 clutch feel. I would definitely do a flywheel. These engines make power in the high rpms, and the flywheel helps it rev faster and get it up in the rpms quicker. However, I've got my heart set on that Corsa exhaust, so I really shouldn't be giving my competition advice.
Old Mar 26, 2006 | 03:36 PM
djt81185's Avatar
Yeah I know...just stage 3 is 150 cheaper than stage 2+. Also the phantom edit got you.
Old Mar 26, 2006 | 03:38 PM
Bad06SS's Avatar
I know saving money rocks, but the 2+ is a better clutch. Also, what is phantom edit?
Old Mar 26, 2006 | 03:43 PM
djt81185's Avatar
I was editing my post when uquoted it...go up like 4 posts. What is sooo much beter ab out the 2+. Looks like it has organic fm compared to the ceramic fm of the 3
Old Mar 26, 2006 | 03:50 PM
  #36
Bad06SS's Avatar
It'll have a better feel and possibly even be easier to launch. In case I'm mistaken, the torque capacity is actually higher on the 2+? Also, I thought that the 2+ is designed to last longer? Maybe I'm wrong, I dunno. Ask Rob what he thinks.
Old Mar 26, 2006 | 04:00 PM
  #37
patathSS's Avatar
Did Rob go with a 2+ or 3+?
Old Mar 26, 2006 | 04:12 PM
  #38
Bad06SS's Avatar
Rob went with a 2+. In his thread he even said "anyone who doesn't go with a 2+ or 3+ only, deserves it to fail!!" Almost word for word.
Old Mar 26, 2006 | 04:20 PM
  #39
djt81185's Avatar
on further review of my budget I may have to ditch the flywheel as a matter of money. Its either CA bushings and a torque brace or a flywheel. The previous will help prevent wheel hop and prevent axle damage. the latter will just lighten the driveline. Choices...grrrr
Old Mar 26, 2006 | 04:22 PM
  #40
Bad06SS's Avatar
Well, I would agree that if it came down to those two, I'd get the bushings. You just need a clutch that can hold the power. You'll be more upset if you get to IDD and can't launch hard because of wheelhop.
Old Mar 26, 2006 | 04:32 PM
  #41
ENUFPWR's Avatar
Good Numbers Dan, Congrats!!!
I hear you on the flywheel.... I just got the clutch also and skipped out on the flywheel. I cancelled the fidanza flywheel because I can barely launch the car in 1st gear as it is... having it lighter will just amplify my 1st gear launching...the acceleration would be great, but not worth it now if I can't hook the car. Besides the company I ordered it from said it was a 1 week backorder... So I went with just the Spec Stage 3+ clutch.
Old Mar 26, 2006 | 07:41 PM
  #42
Darksun's Avatar
Might as well forget about that. Hope for a 2.2 or 2.1 and see what your trap is like. Than again every track hooks different.
Old Mar 26, 2006 | 07:53 PM
  #43
djt81185's Avatar
Crunching some numbers again. If I get a tube of poly and do my motor mounts, jbp ca bushings and maybe get a lil side job at autozone I can get stage 2+ w/ flywheel. I'm gonna see if I can get my dealer to do the gear rattle tsb on my car and when the tranny is out throw the new clutch in there
Old Jul 1, 2006 | 03:05 PM
  #44
midnite06's Avatar
Whats the Cost?
What kinda of HP are you producing? How much has these mods costed you? Total?
Originally Posted by FAST06SS
NICE!!!!! Can't wait to line up at IDD7!!!
Guess mine isn't a fluke now either
Old Jul 1, 2006 | 03:30 PM
  #45
l Sh1ft l's Avatar
yay!!! 4 months later!!
Old Jul 1, 2006 | 05:46 PM
  #46
djt81185's Avatar
now...more than that...we just duplicated my setup on a guy car here...total...700
Dan
Old Jul 1, 2006 | 07:15 PM
  #47
Blown 4-banger's Avatar
Am I the only one who noticed that according to the dyno sheet he made peak power at 5900 rpm?!?!
Old Jul 1, 2006 | 07:20 PM
  #48
patathSS's Avatar
Dan is a liar!!! Don't believe anything he says, runs, or dynos!!
Old Jul 1, 2006 | 07:45 PM
  #49
djt81185's Avatar
lmao actually that is a simulated dyno run...here is a actual dynojet before my latest tune and cat delete.
Dan
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Cptnslo
Sep 24, 2015 09:32 AM
jcalvin1126
Sep 11, 2015 10:24 AM
