3.5" Intake
Old Dec 24, 2014 | 11:58 AM
  #51
Josh@ottp's Avatar
5 people have them already. You won't have water problems if you run a hydro shield and I can always make a different intake you just have to pm me with your ideas.
Old Dec 24, 2014 | 12:21 PM
  #52
mrbelvedere's Avatar
Originally Posted by freakta
does anyone have one yet?
I have one will be on the car next year and dynoed
Old Dec 24, 2014 | 12:23 PM
  #53
Spawne32's Avatar
It's fine, I was just looking for something more a less like the ZZP intake, but given that im a 2.4 automatic swap its probably impossible to get anything to fit in that location anyway. Just debating if its gonna be ok to run double maf extensions with an intake similar to what your building.
are you doing a back to back comparison against a regular 3" intake?
Old Dec 24, 2014 | 12:59 PM
  #54
Josh@ottp's Avatar
I have a 2.4 auto car I am going to test fit the 3.5" intake on. If it doesn't fit I will make one for it. For the MAF extension harness, you can run two or just buy a longer one. I prefer to pull the wires out of the harness for a cleaner look though.
Old Dec 24, 2014 | 01:10 PM
  #55
Spawne32's Avatar
I'm a bit reluctant to start cutting up the harness and moving connectors from their locations should I ever decide to part it out and sell it again, id like it to just go back to the way it was without more modification. Lemme know how it works out for you on the auto car though.
Old Dec 24, 2014 | 01:15 PM
  #56
Stumpalump's Avatar
No clue what a cobalt engine bay looks like but to fit my 4" intake and huge filter on my rear engine application I used one of these or a brand like it. Tight bend high flow. Odd ball part so I thought I would add it in case it helps you. Cobra ElbowsEPDM Elbows
Old Dec 24, 2014 | 01:58 PM
  #57
freakta's Avatar
awesome, please keep us posted.
Old Dec 24, 2014 | 02:29 PM
  #58
Area47's Avatar
Rent me! per hour
Here's a wacky thought. Your TB is 2.5 inches in the opening diameter, and your intake tube is 3.5 inches. Who can guess the resulting issue here?
Old Dec 24, 2014 | 02:30 PM
  #59
Josh@ottp's Avatar
Trevor had one on the dyno. I think it was just a ls4 tb and this intake swap and it was 18hp on a m62 car. Could be wrong on the details though so search for it lol.
Old Dec 24, 2014 | 02:34 PM
  #60
Josh@ottp's Avatar
The intake is really designed for the ls4 tb and for high power tvs cars that are out running the maf table. Even on a stock TB there would be no issue.
Old Dec 24, 2014 | 03:23 PM
  #61
Area47's Avatar
Rent me! per hour
Josh it's not against you. Even you have to admit the days are gone when people question "WHY?!?!" and now it is "uh, ok, i buy it now" Instead of looking into how it works and how it will benefit the vehicle.
A is the problem
B is the solution
X is the result
People forget to solve for anything else other than "OMGWTF SHINY!!!!!"
Hell build and intake that transitions from a 4 inch inlet to a 3 inch outlet with a smooth transition, not a stepped and see what happens to flow. Just throwing out idea's.
Old Dec 24, 2014 | 04:52 PM
  #62
freakta's Avatar
i gained just under 30whp with an ls4 tb on my setup from factory tb. it would be nice to see more gains with a bigger intake, but thats just my build
Old Dec 25, 2014 | 12:17 AM
  #63
Spawne32's Avatar
That seem's very unlikely from just a couple mm increase in the TB.
Old Dec 25, 2014 | 08:48 AM
  #64
Terminator2's Avatar
A is the problem
B is the solution
X is the result
Agreed. A smooth reduction in intake flow path radius will increase intake air velocity (everyone thinks in terms of flow but forget about velocity) as the air nears the throttle body and no turbulence near the throttle body as an added benefit both of which will increase VE (of the intake)
Old Dec 25, 2014 | 09:33 AM
  #65
the throttle plate and intake can become a restriction really fast especialy on a cammed tvs car it dosent suprise me a bit to see him pick up what he did and a bigger intake would probably pick him up some more the harder it is to draw air in makes the blower struggle to ingest air and kills power
Old Dec 25, 2014 | 03:34 PM
  #66
Spawne32's Avatar
Oh a TVS setup, with a small pulley, that would make more sense. Was thinking an M62 with just a smaller pulley, doesnt seem likely to gain that much.
Old Dec 25, 2014 | 03:50 PM
  #67
some m62 cars will see a benifit from it also
Old Dec 25, 2014 | 03:53 PM
  #68
Spawne32's Avatar
Benefit sure, 30whp, i doubt it. I would be more inclined to believe something like...12whp on a boosted car.
Old Dec 25, 2014 | 04:20 PM
  #69
if you can find it on here there is a htread where an m62 car made 21hp under the curve with an ls4
Old Jan 1, 2015 | 06:32 AM
  #70
KTM's Avatar
KTM
I'd love to hear my whine with tvs 2.7 and this on it. :,)
Old Feb 17, 2015 | 04:45 PM
  #71
Spawne32's Avatar
Anything ever come from this? Gonna be in the market for an intake soon enough.
Old Feb 17, 2015 | 04:56 PM
  #72
07blackg5's Avatar
Slobodan Milošević
you can just open up the loom and pull the maf wires out enough to reach into the fender/bumper well. You shouldn't have to cut anything. The wires reach from the ecu all the way to the opposite side of the bay, so they will definitely reach right in front of the ecu. Its kind of a pain with the harness in the car, but its doable
ask me how I know
Old Feb 17, 2015 | 05:06 PM
  #73
Spawne32's Avatar
ask me how I know
Oh I know, harness work is so damn tedious lol but thats likely what I will do. If i dont buy a intake setup already pre done ill probably TIG weld up my own setup. Probably wind up using a maf tube from treadstone as I like their honeycomb grid tubes.
Old Feb 17, 2015 | 05:37 PM
  #74
blueLNFftw's Avatar
Open the loom and remove it.
I have two zzp extenders and all they would do is fail my maf and set a MIL
Old Feb 17, 2015 | 05:41 PM
  #75
07blackg5's Avatar
Slobodan Milošević
I might need to pick up one of these. I don't currently own an intake for the s/c swap
