300hp Max
Old Oct 19, 2005 | 07:45 PM
MarcS's Avatar
The Stig
Originally Posted by UtOhCop
The LSJ's compression ratio is 9.5:1? WTF. GM is really retarded. It should be 8.5:1
8.5 would be better suited for a turbo application where higher boost numbers can be made.
Old Oct 19, 2005 | 07:49 PM
selfinfliction's Avatar
exactly... only running 12 psi, 9.5:1 isn't that high.... running 28 psi on a 9.5:1 would be high... that's why that rebuild of 300hp someone posted they actually raised the compression up to 10.5:1 it won't make that much of a difference on a roots blower, a turbo on the other hand it would
Old Oct 19, 2005 | 10:46 PM
beerbaron105's Avatar
high compression will give u much better low end rather then low compression pistons, the engine will be very laggy till boost kicks in to start pushing that beast!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hhrfreek
Jun 4, 2016 11:25 PM
TedSS
101
Apr 25, 2016 10:46 PM
riceburner
Sep 30, 2015 03:54 PM
