ac delete
ac delete
i know ive posted this before but its been a while and i was just curious if anything new has come to surface that i may have missed. ive been in contact with a few companies trying to get the ball rolling but havent had much luck. i know zzp has some stuff in thw works but they dont seem to wanna let me in on the dirt... so i figured id ask everyone again. thanks in advance guys
why not go to a competent parts store and start looking for a shorter belt. I'm in just about done going turbo on my lsj and have removed all of the a/c lines but still have the compressor on. I might still take the compressor off seeing as gm makes a belt for non-a/c base cobalts.
eh i never use my ac anyways bc the car runs like ass with it on so why not imo.
i can make my exhaust make different notes by just flipping to the different fan levels with the ac turned on lol.
gutting the compressor is stupid. if you ever decide you wanna sell it or put it back in then you gotta buy a new one... why burn money if you dont have to.
you have to make some sort of bracket with a idler pulley. its the only way. the way the routing configuration is set up if it doesnt go around the compressor pulley the belt will rub itself you would need a lightweight pulley similar in diameter to eliminate belt slip unless you go with a custom belt length.
as for using a belt from a cavy or a 2.2 balt... the ribs arent the same one has 5 ribs and one has 6.
Last edited by StevesBlack06; 07-08-2010 at 06:58 PM. Reason: Automerged Doublepost
